CLC vs. CRC
Joined 2004
I believe that the higher value capacitor you have after the rectifier the more spray of mains harmonics will be poured into the amp.
Counter-intuitive to the extreme, or a bit of wishful thinking?
Also with an LT4320 ideal rectifier setup and no blasting diodes, wouldn't the 'mains harmonics' be eliminated?
After this I put one 100mF with low ESR ( FTcap GW ).
In this position I believe it is better to have one big cap rather than several small ones.
What? Since when is one cap better than several smaller, esp for low ESR...?
Joined 2001
Ya you can just parallel a bunch of cheaper smaller values and get the ESR down, but I've seen some of those installations that look awful messy to me. I kind of like his idea of just one high quality large value single cap with super low ESR instead of a herd of several. The big PEH169 and that FTcap are like 4 mOhms or something..
Reactions: 1 users
Redbone and William2001 , Thanks for pointing this out .
I recently bought these caps with 10mm snap in terminals for the DIYAudio Universal power supply board v.3
https://www.cde.com/resources/catalogs/380-382.pdf
380L223M050A052 22,000uF 50Vdc ESR ( 0.023 max - 0.018 min ) 35 mm dia x 50 mm height
But having a look at a PEH169 beast , the ESR is between 4 and 5 mOhms .
https://www.mouser.ca/datasheet/2/447/KEM_A4035_PEH169_85C-3316717.pdf
PEH169KU610VM(1) 100,000uF 40 Vdc
PEH169MV582BQ(1) 82,000uF 63 Vdc
It might be wise to cover the terminals with an insulator
Reactions: 1 user
Uunderhill
The PEH169 in my build are the small white ones 10,000µF 40V 18mΩ.
I don't believe the ESR should be too low at this point.
The beast in my build is the FTcap GW at 100,000µF 40V 4mΩ and 20A ripple capability.
Reactions: 1 user
I've based this on Jan Diddens post.
1/5th of 68,000µF is 13,600µF, so 10,000µF should be ok.
The LT4320 bridge eliminates trafo secondary ringing which is something different.
Insane cap values cause very high peak currents to charge in the short time when the diodes open around the peak of the secondary voltage. So you get high frequency high current circulating, which is hard to keep out of your amp even if the voltage on the cap looks 'nice'.
So yes, increasing the capacity smooths the voltage but worsens the other mentioned factors. There's no hard law but 3 x 68000uF is way overkill. 1/5th would avoid a lot of problems.
The second capacitor at 100,000µF is separated by resistors on plus and minus pole.
This one is not easily discharged, and will only have gently top-up when needed
Sure you can get low ESR by using several small capacitors, but the wrong kind of wiring or PCB layout can easily increase both the ESR and the dreaded inductance to unwanted values.
Reactions: 1 users
Disabled Account
Joined 2002
Supply filters that lead with a choke, such as LCC or LCRC are sometimes referred to as "swinging choke" filters. Their main characteristic is the final voltage is 0.9 * secondary AC, instead of 1.4 (nominal, but realistic 1.3) * secondary AC. However the final voltage only settles to 0.9 after the amp is fully warm and drawing its final bias current. Prior to that, it is possible for components of the filter and amplifier to see the full 1.4 factor, and those components should be rated for the higher voltage.
I don't recall what the stated advantage of a swinging choke filter is supposed to be. Perhaps a final lower voltage might be advantageous in some circumstances, maybe for a high voltage vacuum tube amp. For the lower voltage Class A amps that we typically discuss here, I cannot think of an advantage.
Hello,
No an input choke is not automatically a swinging choke! Hard to find a swinging choke nowadays anyway.
As i have posted before you must take care there is a minimum current being drawn. With a properly designed choke input voltage will NEVER go up to1,4 . If the dc voltage on the first cap is higher than the ac voltage of the transformer you dont have a choke input.
So use the right choke to start with, take care of the minimum current ( know how to calculate it) and then you can tell people it will be beneficial. It will take a serious investment and another power transformer.
If you said you tried a choke input using the same transformer you did not make a true choke input. If you make one better do it right from the start.
Greetings , Eduard
Indeed, rebone.
Eduard even did consulting work for me when I built a choke input supply for my DAC.
But for now, I have never seen anyone building a supply for class A power amps with such tricks.
I know, I must try PSUd software to see the inpact of these design choices.
Disabled Account
Joined 2002
Hello,
The key element will be the input choke. Better have LCRC with a big choke ( lots of mH/ H and low dcr ) then two smaller low grade chokes in LCLC. Especially with high current 1A the input choke will cost 100€ or more. But it will work for decades to come.
Try to simulate with Lundahl LL2733 or LL2771 and you will see what you can accomplish.
Greetings Eduard
The current through all your parts will be at the same level. Making C1 bigger without an input choke and it will only get worse!!!
Reactions: 1 user
Maybe it's a good idea to post this information every couple of years or so :
https://www.hammfg.com/electronics/transformers/rectifier?referer=968
Just remember that you have to compare apples to apples, so the same rectification scheme with a change only of the first element following the rectification - capacitor, resistor, or choke.
Also notice that both peak voltage and available current change with the different configurations.
Finally, you can tweak voltage and current capability of a "choke input" filter with the addition of a (small? large?) capacitor before the choke. It's a continuum of sorts, but what you gain in terms of higher voltage is offset by a reduction in "choke input-y goodness".
Funny you should mention that. This one works a treat with a high bias WHAMMY (200 mA per side), quieter than an easily embarrassed church mouse.
Looking at the power supply schematic of the WHAMMY and the circuit board , its clear why you went down the road of adding an L .
https://www.diyaudio.com/community/threads/whammy-pass-diy-headphone-amp-guide.317803/
Because its a simple addition that would improve the noise floor of the power supply rails ( quieter than a church mouse ) .
But I don't quite understand because I thought those 3 pin voltage regulators chips are pretty noisy .
https://www.tnt-audio.com/clinica/regulators_noise2_e.html
Unless you left those noise generators out .
Long story short , in this application , instead of inductors , suggest looking at a 4th order LPF .
Just a 4 pole ladder filter C R C R C R C R C C .
Also , suggest simulating in the frequency domain , playing around with R values , and look at the roll off .
Also note what rebone has done by putting " The Beasts " as the last caps before the power amp .
Its ESR of those caps is in the ball park of 4 or 5 mOhms . So the current can get to the load ( speakers ).
So the last caps in the ladder filter should have a low ESR .
Reactions: 1 user
I'm not mentioning that you are wrong, but an 8Ohm choke sounds too high for a moderate power class A amp (bias target between 1 and 2 amperes per channel).
I agree, 8 ohms is way too much for that application. The example showed what was done for a class A headphone amplifier so the resistive drop for 0.5 amps is only about 4 volts.
As to your other point, my stuff uses the most ordinary wirewounds Mouser has. Any inductance is a feature, not a bug.
Reactions: 1 user
Disabled Account
Joined 2002
Hello,
If you ask Lundahl to adjust airgap( for free) of the LL2733 to a current rating around 600mA you will get more than 400mH with total dcr of 0,85 ohm!!
I have a friend in Vietnam who used the LL2733 in a Nelson Pass single ended classA power amp, yes for choke input.
It can be done with carefully chosing the choke. And like i said if you know the current being drawn you can ask Lundahl to adjust the airgap. 200mH at 2A will turn into 800mH at 500mA . The minimal current necessary to make it work as a true choke input is MUCH smaller at 800 mH and filtering is much better.
800mH Lundahl in a LCRC will be better than let us say LCLC with two cheap 50 mH chokes. Compare the minimum current needed for 50 and 800mH. Extra current wasted through the " load resistor" will give you bigger ripple.
YES, always use this resistor if something goes wrong in your circuit voltage on the caps will not be 0,9 but 1,4 times ac that is a bog difference. With proper choke input the voltage will be kept at a certain maximum and of course will be a bit lower once your circuit is drawing current ( pretty quickly)
Greetings Eduard
