DIY Class A/B Amp The "Wolverine" build thread
Both my kapton and mica insulator has some clearance in the hole. The advantage for mica would be that it’s thicker and gives more distance to the heatsink.
I might do as suggested and make a new smaller hole in kapton.
Reactions: danieljw
I don't have that (stereo) one done yet. i'm still building it.
I do have one of the wolverines running a sub ! Wow , it can really belt out the watts.
I've built so many amps over the years , I know how it will sound ... no surprises here.
I'm more into reliability/durability , all 4 of my PPM designs sound about the same. under .001%
it hard to tell, PS size will determine the "kick" of the amp cranked up , as will having a higher rail voltage.
My OEM HK680 "runs out of steam" with too many peaks and it's smallish trafo "collapsing" the rails.
500VA does not collapse , my one wolverine can do 200+W all day @ 4R (on my sub).
I fully expect to have a 150W X 2 amp in my little case.
Speakers ? now - a 500W ULTRA 4R sub (below) in a 2.2cu ft box If I had more room ,
I'd buy 2 and build a pair of 3-ways (powered by wolverines). https://www.ebay.com/itm/133555744366 (6 left)
This speaker seem to be a perfect match for my EF3-3. Does not sound like a car audio sub - real snappy bass.
I also have some real powerful 8" dayton RS-225 2-ways , these will be my stereo speakers (along with the sub).
I moved on to 2.1 systems long ago.
OS
Nice! Do you have to do anything different if you are going to be using the wolverine as a sub amp? Also how long did it take you to put together the first one? I feel that with my limited knowledge of building an amp like this, that it will take me a good amount of time to build. I know the instructions are awesome, but I will probably take my time to not make any fatal mistakes.
Please refer my photo here or in my build album.
build album
Drill a neat hole for the insulated shoulder washer then insert the washer and trim any excess that sticks though the other side.
Ok, installed the plastic washer, powered up, everything looks fine.
Went through the steps in the build guide.
My measurment differs from pointed out in 17.1.G "Measure the voltage between TP-105/TP106 and rail connection".
My build is with C004B transistor for Q101 and A004B for Q102. I'm reading 1,4V in TP105 and 0,64V in TP106.
Not about 1,5V as stated in build guide.
Everything else seems fine. I'm able to adjust ccs, offset and bias.
Reactions: ghitus and hcpower
The team manual is quite nice ! I've been building wolverines for a decade now ... really don't need any book.
Sub amp is simple , I'm not using the helper , lower Ic. I actually have another IPS on the wolverine EF3 now.
At 60V rails , the EF3-3 can "unload" all the way into a 4R load and not even come close to SOA.
Couple hours to populate the EF and IPS (1 channel). I took my time and ran both separately before I hooked up a speaker.
Nice! I just placed my order for the boards with Fireanimal!
Meauring my build... Toshibas for Q101/102 had around 1.4-1.5V at both TP105/106 as well.
Rail voltages 64VDC
The measurement would not be affected that much by temperature and not at all by bias unless your current limiting the supply.
Please place a DMM in series with each rail and measure the current draw on each rail. Are you sure the Q102 is correctly orientated?
I measured rail amps and got 29-32mA in positive and 32-35mA in negative.
The tip regarding diodes being affected by the short on Q106 made me do some measuring on D112/D114.
They have no forward voltage !! Resistance measurment shows 2 and 13 ohm!
On the other side D111/D113 appears functional, shows 0,55-0,6V.
So next step is to replace D112/D114. Fingers crossed nothing else is blown...
Reactions: Mainframe
