Schade Common Gate (SCG) Preamp
Ground loops in the AC power can put noise into the system. So minimizing ground loops in the power lines minimize noise in the system safety ground.
On the secondary side of the power transformer, good design and construction should minimize noise in the DC power side of the component. The connection of audio ground to safety ground is for safety, in case of an accidental short that sends voltage and current to places that they should not be. The thermistor ground lift is to partially disconnect the audio ground from the safety ground. It is low enough resistance that it can still conduct current from an accidental short (and its resistance will decrease with current), but high enough resistance that it minimizes any noise that may be in the safety ground getting to the audio ground.
So the thermistor is there to reduce any noise from the AC side from getting into the audio signal.
At least that is my understanding of the situation. 🙂
Reactions: ElArte
That's the way I interpreted it as well. A barrier to prevent AC ground noise from coming in and messing with SCG signal ground.
In my scenario and based on my findings of yesterday...
  • There is a zero-ohm path from SCG signal ground to earth ground through the DAC.
  • There is a ~10 ohm path from SCG signal ground to earth ground through the SCG board and the thermistor.
I say ~10 ohm because it would take a short for the thermistor's resistance to drop to near zero ohm.
So, in normal condition, in my scenario with that DAC as it is right now, there are (at least 😉) 2 paths of different impedance between SCG signal ground and earth ground.
If I connect both the DAC and the SCG to the same power strip, these 2 paths will still be of different impedance due to the thermistor, whereas they would both be of identical impedance with a wire in place of the thermistor.
I really do not mean to beat this dead horse to death. I just hope to wrap my mind around the problem.
Thank you to everyone in this thread for all the help and patience I received! I appreciate it very much.
I woke up with a question.
It may be a silly question. Fair warning.
I understand that plugging everything in the same power strip, surge protection device or outlet is to ensure all grounds are at the same potential, hence minimizing ground loops.
But doesn't the 10R thermistor on the way to ground on the SCG board go against that idea?
The signal grounds of each connected component are in parallel with each other so they are all elevated equally above earth. If each component has its own 10 ohm thermistor, then the actual resistance to earth is less than 10 ohms (10 / nComponents).
Edit:
If any component's ground is connected directly to earth, then every component's ground would also be at earth.
That's an excellent point! Thank you.
In my case, I think it's 10 ohm (SCG), close to zero (DAC), close to zero (power amp)...which makes the actual resistance to earth close to zero overall.
But it doesn't eliminate "multiple paths of different impedance to earth" and its potential to create ground loops...extremely small ones I guess...negligible ones.
Edit: I should have thought about your reply more before replying with this. I think what you are saying is "all components are elevated identically, therefore they see the same ground potential and there is no problem".
My thought is that with the DAC audio connected directly to AC ground, and perhaps an AC ground with noise, the noise is then in the DAC circuit and signal and continues on to the preamp, amp, and speakers.
I am suggesting that based on my system with my amplifier having a thermistor ground lift but my preamp having audio ground connected directly to chassis/safety ground, and all is quiet. So I think I have a quiet AC/safety ground.
And everything is plugged into the same wall outlet to minimize ground loops.
Anyhow, SCG is not guilty here and the time has come to close the lid.
Final pictures of that build:
Reactions: Monk55 and ra7
@ra7 I have been enjoying the preamp a lot. Very lush sound!
That being said, I think I’ll convert it with the buffer when that’s ready. Experimented with some diamond buffer, but the power supply of the buffer could not really handle the awesome swings the SCG is capable of.
Will post some updates next couple of days.
Excellent! The trick is always the diversity of headphones out there, across the impedance/low efficiency - high impedance/high efficiency matrix.
I have been struggling with this a lot. I have, HE6se (50R, 83.5 dB), DT-880 (600R, 96 dB), Focal Clear (55R, 104 dB)…bigger swings, more current, I always have to pick the amp wisely.
But if I could get that lush sound on 1 or all 3 of them, I would be King!
