DIY Class A/B Amp The "Wolverine" build thread
It seems like there might be a demand for a simpler version of the Wolverine that retains it's essence but looses some of the complexity and cost
Just my point with the symasui ... it is the wolverine front end with a symmetrical VAS. Way more gain ! I am going to do a beta enhanced, non-servo
classic Wolverine. It will be different , a true 3Q current mirror and exclusive use of matched dual SMD packages. CCS's will be super simple.
Finally some progress.
All tests are fine, with no issues.
Now it's time to experiment with component placement!
It seems like there might be a demand for a simpler version of the Wolverine that retains it's essence but looses some of the complexity and cost...
https://www.diyaudio.com/community/...lverine-and-cordell-book.400341/#post-7378116
https://www.diyaudio.com/community/...smd-60w-amps-wolverine-compatible-ips.398785/
Just an observation in case somebody wants to take up the challenge.
Then it wont be a Wolverine. The Wolverine is neither expensive or complex, and a smaller version with less output pairs will never match the level of performance.
Layout.
1. Soft start (situated either at the back or front panel)
2. Traffo with electrostatic screen
3. Power supply
4. Speaker protection (18 v DC)
4p - Speaker protection low capacitance power supply
Switch most likely will be at the back panel.
I understand it is ok to:
A. Run AC (RED) wires, twisted straight through the middle via soft start then back to transformer and rectifiers
B. Run wires (ORANGE) from 15V secondaries of the transformer to tiny PSU (4P) and after that run (twisted) along the red wires then split to left and right channels as shown
C. BLUE signal input wires to run along the perimeter as shown, twisted.
D. Amplified signal (GREEN) twisted to run alongside the blue path to the pair of speaker protection and then into speaker hook up points.
As well, can you recommend the location and type of ground without using fancy boards as I don't have them?
Suggestion how to proceed with electrostatic screen 2 wires from the transformer, where to hook them.
Thank you
A couple of notes for @stuartmp and others that may care.
In the older build guide there is mention of D10 and D11 not turning on with a 30V bench supply. A side effect of that is that the VAS may not be biased properly, and as a result, the DC balance cannot be zeroed. This depends on the target rail voltage to some extent, but I have seen it on 1 of 2 EF3-3 targeted at 70.7 volts. A note in the build guide might save someone some time trouble shooting this non-problem.
A while back someone claimed there were no silk screen errors. You may have been joking. Unfortunately, there are two sets of 126A and 126B on the EF3-4 boards V4.0. It's not a problem if you are paying attention and know the difference between emitter resistors and output networks.
Reactions: Mainframe
The build guide says nothing about setting your DC offset with low voltage and I have no clue why you would anyhow.
They clearly wrote "older" guide. I don't know about more recent guides, but In version 24, it says precisely this... perhaps that ties in...
"Immediate lighting of all 6 LED’s. All the LED’s should light in a uniform manner. However, if you’re using a power supply of less than 35 V, be aware that D10 and D11 may not light, as they likely do not have sufficient voltage to turn on. This is not a concern. If the rest of the LED’s do not light, immediately shut down and investigate. Check to make sure that the LED’s are installed with the correct polarity. This can be done using your DMM in the diode test mode. If the LED’s are installed correctly, go back over your work to check for errors"
I do not see 2 sets of 106A and B on the board. There was a 105 A and B.
106A and B? Maybe they edited w/o notation, but that's not what their post says (emphasis added is mine). I have not checked my boards, but I will.
Reactions: wirewiggler
Rectifier heatsink.
The metal backplates of the rectifiers are not connected to any pins (measured it). Can I use just 1 plate or should I seperate them for extra safety?
I could also use some mica insulator but I prefer to just use some thermal grease.
What's best practice, risk etc...?
thx in advance
Tried to connect and test one of the channels via peu + transformer. Blue fuse, but I forgot to change 2a to a bigger fuse. Swapped fuses and wanted to test if I burned anything, connected the bench PSU and now it is tripping at low voltage and d108 is blinking. I all call it a day and will resume tomorrow. Hope nothing serious
