DAC AD1862: Almost THT, I2S input, NOS, R-2R
Stop Clock 2 for DAC AD1862 - PCB
Stop clock 2 for AD1862 #2832 - untested 😀
If someone confirms that it works, I will create a DAC PCB with this logic.
Miro, have you any experiment with Stop Clock 2 for DAC AD1865 and with all 18 bit DAC? I have seen 20 bit conv for AD1862 and 24 bit conv for TDA1541 here.
Can you draw a correct circuit for one 18 bit AD1865 or two AD1865? Thank you very much.
@TokRa This Stop Clock 2 for AD1862 is still untested (but I think it does work).
You can move 2 wires in the schematic to make it work with the AD1865 😉 (but as I told, I am not sure if it is bit perfect, because I did not check it with real digital analyzer, it is only simulated ... in case of an error, those bits would only be shifted by +-1 with those wires).
@Myint67 Maybe yes 🤔
Measure voltages between pins:
1 and 5 (gnd)
24 and 5 (gnd)
9 and 13 (gnd)
... if the voltage on those pins is +5V or -5V then you can insert the AD1865 directly with lifted pin 16 (this pin 16 is not connected on the AD1865!) ... if the voltage is higher, then you can't insert it directly ...
But why do you need to change the AD1864? It is very good chip.
Reactions: Myint67
Hello . I would like to build this DAC, but I don't know what parts to buy and how to order the PCB boards. Is there a list somewhere with each piece? Please be patient and understanding with me because I don't know how to do projects of this kind, but I could stick parts on a board. 🙂
Mouser BOM/Project links
Hope this is OK to share and helpful for those really new to this. Some parts are on back order due to global supply chain issues for electronics. You can use Mouser's search feature to find identical products in some instances.
If anyone sees any errors/omissions then please let me know and I will update.
DAC PCB v1.3 #1351 - excludes the AD1862 chips and the pin headers (assumes you will solder cables to the board). Based on socketed/DIL8 LM6171 opamps,
https://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=ce95e68314
PSU1 #1460 - excludes a suitable transformer, otherwise fully populates the board with screw terminal headers for power in/out
https://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=60a068042e
SPDIF/Optical to I2S #2249 - excludes the 3.3v optical reciever - try TORX147, not stocked by mouser, check eBay/AliExpress
https://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=8d6ea97f46
I2S Input Selector #2526 - assumes on board tactile switch and LEDs, if remote then you can remove item 1 and 2 from the BOM
https://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=8c09689ace
I found this . Some parts are out of stock .
There is even simplier, ask someone to sold you a populated one !
But the ad1862 themselves you have to purchase in a group buy on the eponym diyaudio section, all the parts can be swapped by others brands equivalents but the shift registers.
Eventually you do not need the shift registers if printing the board that can be stacked with the USB to I2S from JLSOUNDS Lab. Read the thread.
@zoom777 I read it but it's too complicated for a novice. I was thinking of something simpler like a project or list sharing on DigiKey.
Perhaps start with a couple of simpler projects (complete kits?) where there are fewer unknowns for you so that you can gain some experience and build up some confidence over time.
Or watch for a forsale of a built unit?
Reactions: zoom777 and Vunce
