Cheap ADSP21489 + 4in / 6out PCM1798 board
Dakle, zvuk je samo izobličen? Jeste li postavili 96k ponovno uzorkovanje chipdip DAC-a?
So there is sound just distorted? Did you set 96k resampling a chipdip DAC?
Thank you @ppp000
I think I set it up well
I'll wait for it to arrive
Nvarcher USB sound card playback recording two-way I2S IIS SPDIF coaxial input and output 384K ASIO
so I'll try it slave mode.
I use google translate
Hello ppp000
I bought
I can't get a signal on the ADSP-21489
I connected it with a USB sound card
(picture BRAVO SA9227-ADSP-21489)
I tried the way I connected it with AKM4495, I don't get a signal.
The USB sound card is correct
I connected it with DAC AKM4495 and it works
(picture BRAVO SA9227-AKM4495)
How should I connect USB sound card BRAVO SA9227 with ADSP-21489
Same way as you connected akm4495, first photo is for input
I tried the same connection method as with the AKM4495, but I don't get a signal.
Is Nvarcher USB sound card playback recording two-way I2S IIS set in slave mode.
When I was shopping, they told me that:
- need slave mode?
Yes. I want it in slave mode by default, but I also want to be able to set it to master mode when I need to.
- The recording can be used as a slave, and the playback can only be used as a master mode
So output(master) of USB to input(master) of sharc. If what vendor say is true it won't work. You need slave output on USB to connect to sharc board.
Now I also noticed that you have pin description on your board? Bclk mclk lrck data?
it creates problems for me how to ask a question so that they understand each other
Thanks for the reply ppp000
Labels on board IN - AB are not correct BLCK, LRCK, MLCK, DATA
I tried to connect slave mode image slave01
I'm getting noise
They didn't understand me from Allexpress regarding the USB interface.
I repeat that I do not understand electronics and programming.
So I need a recommendation for the choice of USB interface slave mode that I can connect (I2S) with ADSP 21489.
I saw on diyaudio.com that Revber posted a picture of how he connected the SA9227 to the ADSP 21489
Is it slave output on USB to connect to sharc board
https://www.aliexpress.com/item/100...516704951208302141e271b!12000026997198680!rec
I'm getting noise
https://www.aliexpress.com/item/1005003740115822.html?spm=a2g0o.detail.1000014.12.6400535bNi0gXE&gps-id=pcDetailBottomMoreOtherSeller&scm=1007.40050.281175.0&scm_id=1007.40050.281175.0&scm-url=1007.40050.281175.0&pvid=fe96491b-f560-4a00-88e9-cb22163e87cd&_t=gps-id😛cDetailBottomMoreOtherSeller,scm-url:1007.40050.281175.0,pvid:fe96491b-f560-4a00-88e9-cb22163e87cd,tpp_buckets:668#2846#8110#1995&pdp_ext_f={"sku_id":"12000026997198680","sceneId":"30050"}&pdp_npi=2@dis!RSD!3260.39!2836.77!!!!!@2101d1b516704951208302141e271b!12000026997198680!rec
What revber posted is new revision of dsp board. DSP there is in I2S slave mode with ASRC. You seem to have older version like me, cause i see STM chip on your board.
Description of SA9227 board seems same as yours. Slave input, Master output. Sent screenshot of SA9227 datasheet previously, should be possible to run i2s output in slave mode.. try do research or make topic here on diyaudio regarding that.
Thanks for your time and answers
It's hard for me to communicate because of English. I am 63 years old.
It would be easiest for me to buy a USB interface that can be set in slave mode.
I read on diyaudio.com forum via google translate CM6631A has 46 pages, not sure which one to choose.
I would like to ask you to help me with your recommendation to choose a USB interface so that I don't make the same mistake again.
