I agree, but the outcome for me is desirable, it seems that the only way to keep GD low and reach desired head room, I'd need sealed 15" or 18" woofers in pairs on each main and the same in 2 satellite subs. I am in the belief that I can hear a change at about half xmax of my subs. Rather than argue details of limitations I'd rather just make it a non issue by reducing excursion to <2mm. In your words "see it move, see it distort"... For plenty of people, designing and manufacturing a waveguide isnt feasible, let alone, necessary, yet the gain in accuracy is desirable and welcome... Having spread out bass sources, ie, a set of vertically stacked dual woofers, in the rear, will increase headroom, and further smooth out FR. Also may create possibility to try a double bass array. Its not super expensive either, so its a kinda, why not 🤷♂️ It'd be nice to have everything set up to perform to 123db peaks, in linear fashion... its was nice at the movies. Speaking of, to think the Imax system was performing that high of levels at well over 12ft?! And no distortion?!, what type of subs are they packing and how many, just wow.Your "goals" make the design unfeasible and are simply not necessary. I know that you have been told that before, but it seems that it needed to be said again.
I never said that and wouldn't because it's simply not true.In your words "see it move, see it distort"
I might of paraphrased a little 🤷♂️...And I do agree that if you cannot see a cone moving then there is no way that distortion in the speaker is audible.
"Don't see it move, don't hear distort...how about that? Either way it seems that less excursion is a good thing so why not keep the trend down to cut off... why not keep the trend at dynamic peak, as well.
I've always thought the pioneers put it rather distinctly regardless of size/BW, 'if you can see it move, it's distorting' and since the distance wasn't ever stated TTBOMK, I used the then Altec [USA?] published 4 ft on axis measurement standard.
"Paraphrased"! More like reworded. What I said is true, but the converse, what you claim I said, is not. This kind of argumentative support is beneath you.I might of paraphrased a little 🤷♂️...
Seeing the cone move does not mean that it is distorted. There are many good woofers with high excursion that are more than linear enough so as to not be an issue. Your position is simply untenable and a waste of design freedom to no purpose.
Yeah, my 'tongue in cheek' response was/is only relevant for those of us using the pioneer's low Xmax design drivers that were tuned down around/at Fs or folks that sufficiently over power their system's linear design.
Guess I need to limit its use to so called 'FR' drivers.
The way that you say the words, I can't find fault 🤣 nor can I find fault with your critique, being that, being exactly precise, has probably been your prowess."Paraphrased"! More like reworded. What I said is true, but the converse, what you claim I said, is not. This kind of argumentative support is beneath you.
"If you don't see it move, you can't hear it distort"....
I think I fit into the "sufficiently overpowered linear design".... the multi independent bass sources are also my best bet of getting a good FR before room treatment. Sources spaced on the horizontal and vertical planeYeah, my 'tongue in cheek' response was/is only relevant for those of us using the pioneer's low Xmax design drivers that were tuned down around/at Fs or folks that sufficiently over power their system's linear design.
Oh ok I thought you meant a person who aimed to have more linear movement than needed by headroom, aka more headroom than needed.Works for me! What I meant though is those folks driving their high Xmax systems to audible distortion.
What conclusion, where and whatabout?I never thought this thread would need 559 pages to come to a conclusion.
I think there are some psychological conclusions to consider.What conclusion, where and whatabout?
OTOH, A lot of good data has been presented, by experts in the field, that could help someone reach a good conclusion.
There's some truth in it."see it move, see it distort".
From a strictly theoretical/hypothetical point of view, there are plenty of counter-arguments to be found, but let's not dismiss reality and pretend size doesn't matter.
Efficiency rules!
(There you have a conclusion )
Being able to come up with alternative ideas, whether good or bad, gets the juices flowing. Looking at the the hypothetical;
What if I put the 2 - 18h+ in a large Tapered TL or BR, say about 500liters, tuned to 20hz, GD delay reaches 28ms at 20hz...whats that sound like? In hornresp I get these cancellations.... I can trust this>?
BR
TaperedTL
No cake and icing here either? Harmonic cancellation unless I use stuffing with these Big vented enclosures?... The 18H+s should be able to be crossed at 350hz... Excursion is low, especially when factoring in the rest of the woofers used for bass.
BR
TaperedTL
I was just analyzing that design matter of fact. Its tuned to 30hz without filling. I want it to be bigger and possibly larger final CSA but it seems harmonics are in the way of the sizes I chose... I just want to check that I am not throwing the baby out with the bath water regarding the responses shown above basically 100hz.Didn't I already do an inverse tapered HR sim with damping that originally met all your performance goals?
The BR port has a 500cm2 in the above and the Taper TL final csa is 314cm2....also the Tapered TL is 589l will teh BR is 513cm2....
When you say ~115db efficient... I assume you mean 115db/4ft and within Xmax on all drivers?No such thing, just a point of diminishing returns, i.e. I found mine when I achieved an in room ~115 dB/stereo/4ft efficient system.
I found that I've asked this question once before, and the answer is a good one
Ok now that I am back on square, @GM I was I trying to model the most efficient enclosure I could, using dual 18"s and a useable bandwidth to crossover to a horn, around 350hz. The enclosure could be big, like 500liters or maybe bigger, depending.
By moving the path length in the BR sim, I can mitigate these resonances
Not sure if a path length feature should be available for TL and other vented sims
Hornresp is one of the few loudspeaker simulation programs that can take chamber resonances into account. A user might wish to mask the resonances when comparing the results against those of other programs, or to mask the resonances when they know that absorbent material will be added to the constructed chamber to dampen the resonances anyway.
The option only masks chamber resonances, it does not mask the fundamental resonance of the system. The most accurate picture of the system is with resonances not masked, unless it is intended to add unspecified absorbent material to the final product, as mentioned above.
- Is it possible to cover the whole spectrum, high SPL, low distortion with a 2-way?
