DIY Class A/B Amp The "Wolverine" build thread
I'm making some progress on my mono blocks. Waiting on speaker terminal connectors for the almost completed amp. Assembling the 2nd amp, passed initial tests with bench power supply, finishing the regular power supply to test further.
You are correct on both boards. I also added a seperate board not shown yet for adding current overload protect to the Bonsai board. Should trip at 7 amps across one output pair. So far I like the Mark Johnson Board, especially having an LED for on and for off. I used an RGB LED switch on the front that will be blue in stand by and red when on. I'm looking to figure out how to have the green come on when the Bonsai board trips.
Reactions: danieljw and 69383
I ordered PCB's for the Mark Johnson circuit last Monday at JLCPCB. Will take a while till they arrive as I opted for slow pace delivery. The price however made me smile.
Might follow you with the Bonsai circuit. The no relay design makes sense imo.
Hi everyone... I've shared my build on the developers thread and it's time to put it out there for others to consider...
My intention from the outset was to build a quad amp to bi-amp my speakers. I began building Honey Badgers until I realized that my speakers are a particularly difficult load rated at 4 ohms, which was pretty concerning for me. So, I contacted Ostripper to see if there were any viable options and he told me that the Honey Badger wasn't up to the task and I really needed to move on to the Wolverine, which was in the design phase.
As a novice, the timing couldn't have been better. I was ready to build and when the time came for testing, I wanted to be part of it for the learning experience. Four test boards later... 2 literally worn out and in the trash and 2 still working and sitting on the shelf, the design and test team finally signed off on the design.
The months of testing allowed me to evaluate the physical layout of the amps in a 5U box, particularly with regard to the power supply. Mounting the boards perpendicular to the heat sink provided enough room for 2 boards and a speaker protection board on each side. The area in the middle of the chassis was going to have to accommodate the transformer, caps/rectifiers, soft start and a fan. I wasn't quite sure if a fan was going to be absolutely necessary, but I thought it would be a good idea to do it now rather than having to do it later.
I made an elevated chassis for the PSU to provide enough space underneath the transformer and cap board for the necessary peripherals. As well, I wanted to provide shielding for the transformer and other sources of noise. The attached photos show how this was arranged. which really worked out well. I was concerned about injecting noise with all the close proximity of everything, but the shielding did its job and testing revealed that it's quiet. Distortion testing revealed that the individual boards didn't lose any performance,
I've been using this setup for several months now and I've pushed it very hard to see if how hot it would get. As it turns out, I have yet to trigger the fan circuit. I have 40C thermostats and according to my temperature measurements the temperature is getting to just below the set point. My wife's set point is being exceeded much sooner... 😆
My heat sinks are running about 37C at idle. The thermostats are mounted to the heat sinks... I tested the operation of the thermostats and as close as I could tell, they're closing at about 42C. I have additional shutdown thermostats mounted on a couple outputs as a contingency. They're set at 50C. At reasonable SPL's the sinks don't heat up as much as I anticipated. I have to push it to approach the fan setting.
Reactions: Johno and danieljw
Fantastic build! 👏
