ADCs and DACs for audio instrumentation applications
Consider also the propagation delays within you time plot 😀 😀
Hp
Propagation delays or timings are not an issue for my original target (I2S input or ADC) since in my case ADC is the I2S master and MCK is not even sent to the MCU. For I2S output propagation delays may become an issue with isolators at high speeds (384k and above). This may be the reason why some of the popular usb2i2s boards have reclocking after isolators.
But when it comes to full-duplex I2S these issues get more complicated especially since there is no data available on the STM32 SAI propagation delays. At least in theory the timings in my case should be similar to Pavel's: #1185. The isolators I'm now using have slightly shorter propagation delays (max 10.5ns) but other than that there is not much else to do if I want to keep this uncomplicated and the costs reasonable.
/Martti
/Martti
So an opened question...
. may simpler or better to isolate the USB connection as I use INTONA gear
. to support one day DSD / DOP as the ADC have to be the master anyway as AKM AK557X
. have to check about DAC as slave
. one thing about using dual ADC as dual mono, they have to be slave as using dual ak557x otherwise 2 none synchronised bck clocks
. as I see to support, ADC only, DAC only and ADC & DAC
. may 2x channel bundeling to get double speed... it is all about bit clock shifting
. may provide 2 individual USB id's so two of them used on same maschine, as using for none coherent measurements
just my 2 cents 😀
hp
It’s a (re)start, but at 113dB SINAD it’s no threat for ESS.
As it goes with Ak4499 ... dam dead 😱
AK4493 as using 3'th order SDM is very very poor 😀
And I am still interested about any PN/jitter figures of AKM and even ESS too 😀
BTW: I would love may ugly UFL connections and for master clock a nice SMA connection with 2 x 100E pullup-down resistors and stay within 30..70% required digital levels.. does this ESS requires too while no NDA :mafioso:??
What do you mean by that? The jitter impact on the analog performance? Won't happen, it is likely way under any usual analog instrumentation sensitivity. Otherwise, I just got (almost for free) a PN9000 Phase Noise (and Jitter) analyzer and I am looking forward for some real world use case. I'm bored of calibrating and measuring Wenzel, MTI, Morion, Bliley and PNI oscillators phase noise and jitter 😀.
Mine does everything, from 2MHz to 26GHz, all known PN measurement methods, PLL OCXOs (10 & 100MHz), Synthesizer (2MHz-1.8GHz base band, up to 26GHz with up/down converters), Delay Line, Addded Noise (with autocorrelation), VCO, etc... Two racks and one computer, 160lbs. of equipment.
I'll post some test measurements later.
Yes, all about PN measurements and figures... not what happeneds at the audio end 😀
ADC/DAC added PN/jitter happens IMHO about limitations of the internal switching capabilities... Audio Godfathers do not like to blame turtles ... so after time anyone will get sooner or later after the ****.
This is my first clock generator measurement. Schematic (there are a few changes)was posted in this thread. Essentially, it's a fractional PLL that generates the audio master clocks for the ADC and DAC starting from a fixed reference of 24 MHz (a 50 cents quartz) which is also used to clock the XMOS CPU. For audio purposes, this is followed by a series of jitter cleaners (also PLLs), based on the Cirrus CS2100 chip.
Attached is the phase noise plot for the worst case of 100MHz output (close enough to the 98.304MHz required for 768K conversion). Reference for the measurement is a Morion MV317 100MHz OCXO. I am sure Andreas will be deeply disappointed on the results 😀.
There are some spurious I cannot identify the source from (they appear always in the same frequency range), also I cannot explain why the noise slope seems to decrease at very low frequencies, but then I am not going to sweat too much over those details.
Also attached is a photo of my new toy in action, while measuring some 10MHz oscillator (nothing to call home about) 😀. Now I have to find a good location for it, in an already overcrowded lab...
Really? and why?
The poor Timepod measures exactly like your PN9000.
Already compared, maybe you have not read carefully
The Well Tempered Master Clock - Building a low phase noise/jitter crystal oscillator
You are right, we are not particularly interested on listening to your devices.
And I well know there is nothing for us here since you still keep measuring THD.
However, now you have a good phase noise analyzer tool so you could build yourself an upconverter in order to measure in audio band (at DAC output).
And maybe if you share the upconverter design you saved us a lot of time.
