Amp Camp Amp - ACA
I have even forgot to solder both sides of the .47 Ohm resistors on one board and the amp didn't mind. Took me a while to figure that one out.
I didn't even know you were supposed to do that. Am I supposed to do that on the .68 Ohm resistors too? What was it doing that it took you a while to figure it out?
I'm looking these these instructions, and the v1.8 instructions for the back panel... am I missing anything?
The resistor has two leads that pass through the circuit board. I only soldered one lead not both. The board was mounted to a silver heat sink and that made it look like there was solder in the hole. Then I noticed that the flashlight beam went right through the hole. Just had to un-mount the board and solder it up. Could have done it from the top but I wanted to see if I missed any thing else.
They do not need to be matched for the ACA as it only has one per channel. The store has jfets listed under active devices but sell them as a quad (4) set. The potentiometer is a 5K ohm value and can be purchased in an assortment on amazon. Search for 5K potentiometer pc mount.
Does it matter which one?
The jfets are 6-8mA and 8-11mA? I also need the Q3 transistor which I was told was a bjt? Will that come in the set of 4? Trying to get everything shipped at the same time.
jh
Breakthrough! : DigiKey now stocks Linear Systems JFETS as specified for the ACA. Here’s what you need, and they don’t need to be matched as there is only one per channel.
ACA JFETS at DigiKey
I suspect it makes more difference that many would expect! I do know that putting it on a shelf with another shelf 30cm above makes it a lot hotter. I also know one person who put an ACA in a 30x30x30 cm niche, closed on the back and the amp got too hot to touch!
So best Is on a shelf with no sides or top, ie open air, and yeah, taller feet or on a pedestal. Obviosly don’t put a preamp on top!
Yo, Iguana Mate!
this is really Papaland!
you Boyz even named JFet quartets and octets, by Pa!
:rofl:
I love my ACA. I am listening through Freya preamp tube stage and yes I don't have the center channel clarity like the other amps but this thing just sounds good. Thanks Nelson.
End of the week will have the replacement parts in and will get to here two ACAs in mono.
JH
