I'm building a $4000 speaker kit ... Which one?
I thought the dips where more alarming ;-D
Where would the lobes come from without the dips 😉
I'm actually okay with this, as long as I can get an AMT or ribbon in a waveguide. The only requirements are high efficiency and better than the TPL-150H.
The Viawave ribbon drivers were mentioned before. They are somewhat unique in having the gap blocked making them sealed. This means they are usable to a lower frequency with less distortion which is often where ribbons fall down.
They are available with and without waveguides. They could be paired with other high efficiency drivers.
Joachim Gerhard has a speaker using one with a waveguide and a Purifi woofer, Troels has the Atiri without the waveguide. The raw drivers are expensive though.
ATiRi
Viawave GRT-145
Viawave SRT-7 ribbon tweeter | HiFiCompass
Does these options change the BSC, and make the baffle effectively larger in this regard? Screw things up?
The information krivium gave you is correct but you need to remember that 220 to 250 Hz is in the transition / modal region where the room is becoming more of a factor than the speaker. Without EQ, room treatment or cardioid like directivity the difference in baffle step will be swamped out.
It is better than straight edge.
The optimal? It'll depend from a lot of other things including width, depth, height, driver location,... to be sure only simulation can give clues imo.
Have you read the post i linked ( and the ones following) from Patrick Bateman? In my view it summarise well the situation.
Flaxxer, do you mind if i come back a little bit on amp power (i would like to comment on the Harbeth video Fluid linked)?
If you don't want just say no.
By all means, go ahead Krivium. This thread has been all over the place since I started it, lol.
You may have misunderstood one thing however ... the added 45 beveled edge sides would be added to an EXISTING speaker. So there would be zero ability to change anything in the xover. I'd just be adding an extra 19mm layer of plywood to the sides, but with the 45 degree bevels.
Could you give the width of the loudspeaker in question ( Asathor?)?
As pointed by Fluid with a loudspeaker of this size the bsc should be in the vicinity of schroeder frequency and thus the room will start to dominate the behavior, so lowering this frequency ( by adding the sides) should not change a lot in fine.
That said if you have the drawing of cabinet you can simul under 'the edge' to have an idea. It won't tell you exactly what will happen but'll give you a trend.
Ok so the regular width ask for something around 348hz.
With your side added it should be around 304hz.
If your musician it is a drop from an E to a D.
It shouldn't change many things but i thought the cabinet was wider.
I'll see if i can find the edge on one of my old pc and simulate it.
I'll save you the trouble
Difference between a 440mm baffle with no edge radius and a 478mm baffle with a 19mm edge radius, so little that I had to double check I did it right as I could hardly tell without the gif 🙂
attachment.php
speculating... but he (like me) had a strong preference for sealed box designs over vented box designs. Obviously he liked dipole pattern bass systems the best. But among monopole systems, he seems to have been a strong advocate of sealed box designs combined with thoughtful EQ (the Linkwitz Transform).
What I do not understand is how the original crossover can work while removing one of the two tweeters!?
If you are open for DSP, I would consider to buy a pair of Fusion 253 or 503 as suggested before. As you are handy with wood this will give you a lot flexibily to swap units over time in case they are not satisfactory. And they will make the response flattening and fine tuning to taste much easier...
I use a Fusion 253 in a dipole design with Heil AMT, 6" 18 sounds 6ND430 mid and a long excursion 15" woofer, very happy with it.
You do not remove any tweeters. Supertweeters are added to the speakers existing binding posts. They have level and slope adjustments, and can be turned off as well. Unless you engineer this into the xover.
I'm pointing mine backwards and up, via a flush mount board, just over the size of the tweeter flange, which is hinged to angle upwards at any angle you choose or be flush when folded flat. A wooden hinge of course.
Yeah designing a waveguide for a ribbon, or finding one with a waveguide isn't easy. I can't really see finding a ribbon with a waveguide already as something that will happen. You'll have to design your own and one of the right size to match the woofer you would intend to use. None of this is impossible but it's definitely a headache to overcome.
No thank you. I'd prefer not making my own.
I wonder of the TPL-150H can sound better with a rear facing super
tweeter? To my ears, "air" was what it lacked when I heard them.
I'm still VERY stuck on using a G1 ribbon in the future. Maybe with 6" MTM design. Pro mids ... maybe
Eighteen Sound - Professional loudspeakers
or maybe ...
Faital Pro 6PR150 6.5" Speakers - Faital Pro 6PR150 midrange speaker that has a lightweight neodymium magnet - Faital Pro 6PR150 300 watt 6.5" has an efficiency of 97dB SPL woofer for all high quality midrange applications. Faital Pro 6PR150
