Simple DSD SRC for BeagleBone
  • readme.pdf
    readme.pdf
  • DSDit_Amanero.pdf
    DSDit_Amanero.pdf
Reactions: minhtuan110qt
When I commissioned the factory to manufacture the DSD'it SRC4192+AK4137 board, I encountered some troubles. They said they couldn't understand which of these two inductors should be purchased, so the current manufacturing process has stopped, so I need to know the specific values ​​of these two inductors. thank
L_Core_Ferrite_Small L_0603_1608Metric
L_Core_Ferrite_Small L_7.3x7.3_H4.5
I found that the CT7302 / CT5302 made by ComTrue, a Taiwanese company, seems to be stronger in specifications than the AK4137, and the price of the CT7302 is about $20. CT7302 / CT5302 is integrate with SPDIF.
However, ct7302cl was launched very early, but it is still unknown. I don’t know why? It may be that the company’s product is only SRC, so that it is unknown.
Can CT7302 / CT5302 be integrated with src4192? Or is it compatible with two CT7302 / CT5302?
ComTrue Inc. - Audio SRC Bridge
IME, CT7302 sounds much worse than AK4137. We have already discussed this stuff in another forum thread.
Also, regarding the use of ferrites for cleaning clock power: Probably better to avoid them unless experiments show they are really necessary for a particular board design. IMHO only, I believe they can create hysteresis noise that leads to increased clock jitter.
sorry guys but I am not sure of understanding how this board works. Is it possible to use it with USB DAC? SPDIF? How?
I mean, stream is upsampled in the DSDit and DAC is connected to the BBB via USB....😕😕
Hi jmmbarco,
According to the original design of the DSDit SRC board, it is to provide the DSD signal required by the DSC dac. However, the conversion board I designed by myself can connect the I2S signal output by the DSDit SRC board to Ian's Reclock.
However, no matter what kind of DAC can accept I2S signals, of course it includes the I2S signals of the DSDit SRC board, but you need to find a way to correctly connect the I2S output of the DSDit SRC board and the I2S input of any DAC.
The purpose of the SRC board is to output high-quality DSD signals without requiring a powerful PC. According to the designer's experience, the DSD quality of the DSDit SRC board is similar to that of Roon.
Just done soldering the board.. this will be for the DSC2 DAC with tube output stage.
