It would be good if you can make a recommendation for a 'right WiFi device' - I assume you're using a USB WiFi dongle?You are wrong. WiFi working out of the box. No drivers needed. If you choose the right WiFi device
My SanCloud beaglebone has onboard WiF and I'm guessing the Pure distro may not have the driver for it, but I have found some info that I will try to check out.
as far as I know on BBB it is not possible to use WiFi dongle.
I use WiFi repeater near the DAC
Can I just clarify, so the actual connection to your NEO3 is via an Ethernet connection from the repeater?
