Acoustic Horn Design - The Practical Way
...ARTA with a Scarlett 2i2 sound card and a MicW 215L measurement microphone....
Have you found the MicW 215 satisfactory?
I plan to measure some prototype horns and the MicW215 looks like a nice choice.
The prototypes will be foam, probably XPS, I noticed a few people have tried this, any advice or tips on easiest fabrication, before I start?
Best wishes
David.
Best wishes
David.
Yes, I like it.
I use the L-version with lower sensitivity. We have sold well over 100 of these for an SPL-logging application, and it was best to get the low sensitivity version to be able to record peak SPL in the +130dB range without overloading the input of the Scarlett 2i2. There has been very little problems with these in the field.
The mic comes in a box with a mic holder and a foam wind screen. They include a calibration chart and a correction file on a USB stick.
The mic holder is not well designed. It tends to come apart in pieces when you take it off the mic stand...
Not a big deal as long as there are alternatives.
Bjørn
I was unaware there existed a low sensitivity version, what is the sensitivity?
What price do you sell them for?
The mic holder...tends to come apart in pieces when you take it off the mic stand...
The one I am offered doesn't seem to have a correction file.
No problem, I can create one from the calibration chart, but I suspect it is because the mic is old stock that has sat on the shelf for years.
Should be stable by now😉
The mic holder is also no problem, I won't use it anyway, just an extension tube out the back to minimise reflections.
Thanks for the information and best wishes
David
David
Retail price here is 500 USD.
Low sensitivity version is 11mV/Pa. Standard version is 40mV/Pa.
Send a mail to Vincent at MicW with the serial number.
Maybe he has the correction file in his archive.
guowei (at) mic-w.com
Bjørn
Working on speaker for my father. STH260 with Tymphany DFM-2535R00-08 below.
Reactions: N173MM and Naturlyd
First, let me summarize how to import the shape into Fusion 360 since it is still not properly documented in the User Guide.
Definition file parameters (4.5.0 and above)
Output.Coords = true
Output.Coords.NumProfiles = 8 ; Number of exported curves in "_profiles.csv" file (default = 4)
Notes
Two files are created in the project folder:
<project_name>_slices.csv
<project_name>_profiles.csv
Now there are two Add-Ins for Autodesk Fusion 360 included in the Ath package:
Ath4_CurvesImport - used for spline-only import, can be used either with the "slices" or the "profiles" file
Ath4_SurfaceImport - used for lofted surface creation from the "slices" file.
The number of curves in the "slices" file is controlled by Mesh.DepthSegments parameter.
Installation of the Add-Ins in Fusion 360
1) Tools -> ADD-INS -> Scripts and Add-Ins
2) Click "+" in "My Scripts"
3) Select the folder "CurvesImport", part of Ath package
4) Repeat steps 2-3 for the "SurfaceImport" folder, part of Ath package
Hi Mabat,
Is it correct that this is still not included? Could you maybe let me (us) know how a Fusion 360 import can be done with the current version? I cannot find the import scripts within the ath package.
