L12-2 CFP Output amp 120W*2 8R
Do you have the circuit that you used?
So I would have to do some smd work🙁 I do see to use DIP8 ADAPTERs. Do you think I would have to do anything special to this circuit? or use it as is?
I do not know this circuit and I can not help you, I do not know. I bought a simple OP bracket with parts already welded. is this the best circuit with choice of coin values, i don't think so. But what I am absolutely certain, the result is perfect.
Dual OP Amp Preamp DC Amplification Empty Board for NE5532/OPA2134/OPA2604/AD826 | eBay
Should have put the op-amp type😱 and a revision
This post probably does not belong here but I wanted to have gain or volume pots for the L12-2 amp. Something that works.
If anyone is interested, I can post the schematic I used for the VU meters. It gets its signal from the speaker out-puts and there are pots to set-up for max VU when amp just starts to clip, looking at a scope sine wave. It runs completely from the speaker outputs.
The LED lights are fed from a 2 volt regulator.
