3 Transistor HP Amplifier with low dist
So be it master. Formula3HP
Your padawans will obey.
Great to see this made into one of your PCBs Prasi. And interesting to see an AC input rather than DC-DC regulation. I'd be interested to see if it makes a difference using linear power rather than an SMPS.
Hello avtech,
Thanks..
just thinking out loud here.. would it do any good to put a 5-10mH choke at the power input when using smps? I think I had seen this in one of the DIYA hpa using smps power.
About the input capacitor = 22uF electrolytic
That cap was only used by me because sometimes my simulator measure correct only when is a high capacitance.
In reality I would recommend a film cap of value 2.2uF
That is quite alright for the input.
Those that can find a polyester or MKT of size 4.7uF can use this.
But as said, 2.2uF film cap will do perfectly.
This shows that cap:
Finally happy with this version.
here 2.5mm, 5mm,7.5mm,10mm, 15mm pitch caps be fitted for C2, also small heatsink 274-1AB can be fitted for BD139. LM317 can go on bottom plate if required. In psu, RC/ CRC optional..
Very nice Prasi. Like it very much.
I updated my layout for a film cap 2.2µF/50V. PCB is 60x70mm.
I will order 5pcs. in the next 2 months so happy to share some with DIYers in germany for cost of PCB+shipping.
I think it would me much easier to adapt/use the circuit with 9V at least
but I´m sure lineup has a more eloborate answer for you.
Can you get hold of a ~12VDC wall wart? (AC would work too with Prasi´s circuit)
A little DCDC-converter that converts your 5V to 12V would be a good option too but it would need about 0.5A from your 5V supply.
What´s the impedance of the heaphones you wann a drive with it?
Just remember if you are feeding a LM317 regulated circuit, you need to supply about 4v above the regulated voltage.
For a 5v (or 9v) circuit, you'd probably be ok with just a simple CRC filter at the front.
As joensd suggested, a DC boost converter would be a good option to retain the PSU filtering and not have to change the amplifier circuit.
Hi Lineup,
Can this circuit be adapted for a 5V supply?
Circuit can be adapted for 9V, but probably not 5V.
But if you are using 9V battery - there is a big problem: Circuit draws 100 mA.
That would empty battery quickly.
Best is to use 12VDC with a LM317 regulator.
For 9V regulator we need to change some components values.
Here is one version for 5V.
It should work eventhough the dist is a litter higher.
THD 0.009% instead of 0.001%
It is possible someone could tweak this 5V version further.
But the distortion is still very small for this version.
The gain is here x3. The original has x4.
