"WHAMMY" Pass DIY headphone amp guide
UNI-T are awesome bang for the buck
Does anybody use a Sennheiser HD-560S with Whammy? I opted to get one of these instead of the DT 880 600 ohm's.
It's 120 ohms and very sensitive at 110db @10khz/1V RMS. I would like a sensible volume control, at least half a turn, and I'm contemplating reducing the gain by reducing the resistor values of R4 and R8 to 2.2k.
But if the volume control is usable from 6 o clock to 12 with the stock values that I have already installed, I'll not go through the hassle.
On the schematic it says "R39 and R40 can be changed to vary overall gain as a voltage divider with P1."
I lack the engineering knowledge to know what the math on that would be, or what the pros and cons would be between that and changing R4 and R8. I think the voltage divider just knocks down the input signal which I guess could cost you a little SNR.
There are resistor sockets available that would at least allow you to experiment without soldering and unsoldering the same pcb pads.
Swifty - What does clock position have to do with the ability to drive Sennheiser? Turn the knob until you get the proper volume, you’ll have plenty of range. :yes:
Many people use the higher impedance Sennhieser with Whammy and report outstanding results.
I am fearing that the sensitivity of the Senns will limit the travel range of the volume. If I have only 25% of a full turn on the volume knob, from whisper quiet to shatteringly loud, t will feel like I have to fiddle too much to comfortably change volume. A bit like having a stepped attenuator with too little steps.
Also, I often listen on moderate to low volume. I want to keep the volume pot in its range where the channels are matched best. I find that on their lower range, pots can be quite mismatched in volume per channel.
I am hoping that tailoring the gain resistor values will give me at least half a turn of control.
I will probably just add a gain switch.
Another question: I am tapping directly into the 18v secondary rails for the power led, with added diode, cap, and resistor to tone it down, protect and rectify it. I tried without a cap, but to me the 50hz flicker is noticable. I settled on a 10uf cap as this makes the led turn off pretty quick, but also gets rid of the flickering.
The AC voltage is 21.4V. Am I ok to use a 25Vcap? Or will I have to take into account voltage spikes larger than the measured voltage?
In that case I made an anniversary edition 🙂 Although I just finished wiring it up this morning.
I ran into an issue: While there is no hum at all, and the right channel is quiet, there is a hiss in the left channel. Also, there are cracks and pops in the left channel when I plug in the head phone. When I turn Whammy off, you actually hear the capacitor discharge in that channel as well.
There is 17 volts on both rails, 570mV on both channels
Any pointers?
EDIT: I put on some music and the "quiet" channel hardly has any volume. Hence the silence 🙂 The hissing channel plays music, but at a volume that cannot be correct. I can turn the 10K Alps pot all the way open and the music is only moderately loud in the left channel.
Is it "well-lit and in-focus photos" time?
I solved it. I had installed a 0,1uf bypass cap on the underside of the opamp socket. As this was the only deviation from the original schematic, I started troubleshooting by removing this cap.
This solved the issue. I now only hear the faintest of hums when full open. at least half a turn beyond permanent hearing loss level. I'm happy.
She sounds absolutely wonderful, amazing stuff. I'll post some beauty shots later 🙂
That should be fine for the LED. You can convince yourself of this by looking up the cap's data sheet and seeing its derated value. I suspect you'll find the cap can handle 35v or thereabouts, and certainly for short pulses, without any issues. As to the value, I've personally used 47uf@50V and 47uf@35v rated in my 3 now for over a year with no issues.
--Tom
Here is my anniversary Whammy with a few toys. Dexa UWB regs, Muses Volume into Sjöström Super Buffers and the 994 Ticha op-amp.
The sound is remarkably good, the buffers are an experiment to practice using them, they will ultimately turn a power amp into an integrated and work very well. Perfect clear sound.
