Amp Camp Amp - ACA
Reporting in with what seems to be a success:
Took about seven hours. Sounds great driven directly from my PC, however the max volume is not too loud, so I think I may need a pre-amp.
Ok, back again with the humming.
I have found the source but not the solution.
If I power up with no source connected the humm is much lower but as soon as I connect a source the humm is back.
I don't own a preamp yet (got parts and board for a BOZ and jFet BOZ) so I am limited to Chromecast audio and misc phones/tablets but battery or line powered doesn't matter.
I tried a starground with some alligator clips but that didn't do anything.
I then tried to elevate the signal ground by adding a 10R resistor (in series) between the RCA ground lug and the signal ground connector on the board but that didn't help either.
this is the reason i switched to using smps psu's...
...just finished the ACA 1.6 with back panel power button...first power up everything worked perfect. This is the only electronic build, except the AC Preamp build, that I haven't had to troubleshoot in some way.
I'm driving it with the B1 Korg that was finished about a month ago and it's powering BOFU bookshelf speakers built years ago...very very nice and thanks out to Nelson and Jim for the guidance.
...still have two more 1.8's that will be used a monoblocks...
Mario
rule of thumb really - for each rail Volt, take one KOhm
if that's still too bright, just double it
that's at least one thing, for which I don't need calculator anymore
i also heard NP say that in his interviews or lectures that he is also tired of calculations, he use a pot and then turned it to find the operating points is fine then get the equivalent fixed resistors....😎
i tried toroids, ei traffos and humming was the issue, can not tame the hum....what to do? smps to the rescue...
One sure way to kill hum is to use 2 trannies back to back, unfortunately only feasible for pre amp use due to cost and space constrains.
For linear supplies lots of RCLC plus CapMX followed by more RCRC.
N.B. It must be RCRC, not CRC.
So, at the end, Tony's advice is very sound, SMPS kills a few rabbits with one bullet.
oh yeah
he's doing these things since right after moment of wheel invention ..........
second nature is thing of past, now he's doing it as first nature
:rofl:
Ok. I tried the changes but it still blows the 2.5A before each transformer.
When I was testing on the bench I did NOT have the added 2.5A Fuses in front of each transformer which probably explains why each amp worked fine then.
Any harm in increasing the rear single fuse to 4A and increasing each fuse in front of each transformer to 2.75A or even 3A?
I’m quite embarrassed but I fixed my problem. A couple of the keratherm pads I used had been penetrated by the screw holes of my chassis (don’t think dirty, haha). The Irfp9140 on one of the boards was for sure sending voltage into the chassis and I caught it. I sanded the screw holes and swapped out all the keratherm with mica and thermal paste and everything is working perfectly.
I fired up only one channel and still buzzing.
Reconnected the old 19V laptopbrick and dead-quite (just as you said).
I don't want an external supply so I found a cheap 24V 5A SMPS that I plan on mounting inside the chassi.
I just hope it doesn't die due to the heat.
DC 24V aluminiumlegering interna stromforsorjningar for LED-skarm, CCTV, stromforsorjningsadapter for LED-skarm Ljusstang 3D-skrivare(24V / 5A / 120W): Amazon.se: Electronics
