Salas SSLV1.3 UltraBiB shunt regulator
Thank you for your reply. Unfortunately the order is already placed.
is it possible to use one of these for 15V negative supply?
Do you guys have a coming GB for this?
I'm not about to copy it, but I'm sure I will not wait months.
Do you guys experience that this circuit would be superior for a headphone amp, comparing to a Jung superreg?
Thanks,
JG
Hi, Did you get a conclusion in this question?
I'm considering to build a jung superreg. (earlier I've built a salas v1.3) and would be curious for others' sound comparism)
HI Salas,
I would like to build your v1.3 (pos and neg) before that I thought it is a good idea to modell it in LTSpyce. but for me a high frequency oscillation is shown. What am i doing wrong?
Thanks in advance,
Szabolcs
  • salas.asc
    salas.asc
HI Salas,
Thanks in advance,
Szabolcs
I see nothing weird when running similar .tran parameters in my original modeling. Don't know, change M1, JFETs, BC models in your analysis? They don't directly correspond to BOM many of those you used. Put some ESR and ESL in your electrolytics modeling also.
Salas, in your experience, is what he is showing - 20 mV at around 4400 Hz - going to cause a noise issue? I was looking at using this regulator with a B1 Korg so it would go through another set of filter caps too.
Thank you. I am looking forward to building this.
-Geoff
Thanks for confirming the green LED.
I read in another thread about Muse ES BP caps actually having a better orientation. I did notice the longer lead and the lettering on the label being aligned.
Did I put these in how one would deem the best way? I learned of this after soldering them in!
That's not a purely technically explained orientation preference but a subjective recommendation that I haven't explored. These non polar capacitors are most possibly made by the same assembly machines that produce vastly bigger quantities of polar capacitor types, and that's why they retain a standard legs length difference I would think. A difference that of course serves no essential electrical polarity notice anymore in a bipolar type like the Muse ES.
i think it is a long shot but i thought i might ask.... 🙂
would it be feasible to setup two separate positive regulators with slightly different output voltage, and then connect their positive voltage to each side of a given load to create a low voltage regulator? I know there are single supplies available for that purpose, including the digital version of the regulator described here.... but i thought it may be another avenue to have more flexibility...
Whatever theoretical voltage sources combination is also doable with regulator outputs. A common reference return point is needed so to correlate. In case of utilising a level difference between same polarity, the load should be floating.
