My F4 build (questions, bragging, and other thoughts)
P1 Trimpot to max = clockwise 25 turns = output ≈ 5k ohm?
be inventive - find a way to check with ohmmeter
I can't remember and I don't care much about CW/CCW even on my own pcbs, always trusting only what DMM is showing
Not sure about how to connect the trimpot (not p1) in series? In-out is easy but where do I connect pin 3 / gnd?
sorry, I wasn't precise - I meant P1, not additional trimpot
just correct 10K position, as already told
Thank you ZM, good advices as always. Measure output I would have anyway [emoji1]
It would/will be SO cool if baby-F4 comes to life after just this issue!
[emoji1317] david
I‘m a bit in type-before-thinking-mode, most of the advices become clear just after i go „huh?“... [emoji51]
now it's closing in...
Heya!
Got a spare hour to try doing the correction.
Replaced R8 (22.1K) on first channel, switched on (first with light-bulb, then fully) and here's BIAS! instant 0.13mA, offset between 0.00 and 0.03 mA.
Next question: Why does it not get warm? The channel has been on for ~15 minutes, no real temp-rise.... (heatsink and device are both room-temp, 18°C)
This time it looks good!
R9 is 5K and I get 200 mV bias (slowly growing, me gently keeping it below 200 mV), still jumpy offset close to 0 mV.
It‘s warming up and I am very confident!
Thank you for chiming in so quickly, dennis!
[emoji4]
My turn to feel embarasssed [emoji51]
But it’s on it‘s way. I connected both channels and threw it on which instantly blew a 2A fuse. On a 230V line it is running btw...
Having a break until ... thursday if I‘m lucky.
When I was in need of a little distraction, I went to the chassis and tried my mechanic skills, making a prototype of the LED-indicator:
Since I have dozens of rectangular leds, I'm using them for the front. Cutting out a hole 5 x 2 mm is a bit of a challenge though. (As one can barely see, the LED sits snugly, but the cutout got half a mm too long). I luckily made it on a spare part.
Next try: round the led, make the hole 5 x 2 mm with round ends...
edit: That yellowish stuff is the masking tape protecting the anodized aluminium.
Did you set P1 to max value before you power up the other channel. With R9=5K
(and I'm assuming R8=22.1k) the TL431 will give fairly high Vgs voltages even with P1
set to max (~5k) and you may already get a healthy amount of current
flowing through the mosfets. And if P1 was close to zero that current will be very
high.
