the next steps (mechanical bragging stuff):
modushop‘s antivibration feet are bugging me, dont like the plastic and especially I‘m not convinced of the fact that they‘re supposed to be attached to the 2mm baseplate, it _will_ bend!
How did you do it?
Then, getting the faceplate done. Sorry, ZM, no lenco-logo, I‘m on thorens and won’t even put this one on 😊...
The power-switch is also a little bit a challenge, have to lower the torque and have it sound better (it’s too hard to turn and sounds clicky.
you silly boy
see on pics of my builds where I did put (any) sort of feet to Modushop case
in short - foot is under the base of heatsink
I half-heartedly looked around for a build of yours with a modushop-chassis and concluded it wasn‘t that important after all.
Will find a solution of sorts...
[emoji1308][emoji4]
[emoji1308][emoji4]
I have my amp resting on my cat, and when he’s not around I use a bicycle wheel hose. I like the cat the best, makes for organic sound.
I don't like modushop feets too.
Their construction is at least funny.
Cheap painted plastic.
I had to drill these down and use longer screws so that they do not rely on the adhesive rubber.
Check out pic 14-ish: SissySIT, another one – Zen Mod Blog
Mister mighty-man McZenMod has raised the UMT bottom plate with standoffs, so the alu holding the sink together is the only place left for the feet. There are six holes visible, he prolly used the outer 4. the. Again, Mighty might surprise us and do it asymmetrically 🙂
I’ll do it his way next time. The feet are always in the way mounted on the plate itself.
I agree with Thimios. It is a strange patent, not thought through I would say. But then they are Italian.
Does it purr depending on the input? 😀
Ah, and don't pun on Italian style! 😉
Yes, he did purr, but unfortunately he died one night when I biased up to 115 watts dissipation per sink. Now I lost both the cat and the 50hz intermodulation w/harmonics his purring poured into my bass.
I got Russel wrong, he had that pic of his cat on top of the amp in the BA-3 thread. I got it upside down...
Today (or was it yesterday?) I readjusted bias to 250mV and gave it a go with random favorite music from my computer.
There it is, that impression of having something special going on! It seems I begin to re-discover my music-collection... Even with the flimsy little furutech-pre/headamp (1V output max...) I get reasonable, and indeed listenable sound. Not really loud, though, but really enjoyable. So much that I forgot I actually would have had to work 😀
It seems that there _is_ a run-in / burn-in (or whatever that's called), I wonder after how much time that gem will be fully developed?
I like it very much.
How is it going, and how is the WLS playing (with the F4?)
Haven’t seen you in a while. Not Corona, an avalanche or a flood or something else deviant happened to you?
I see 4 motor caps of 50uF for PSU
are these good for PSU?
Choky loves them. Chede uses something like it too. If I had room I would too. I am using small 10uF as specified by Papa in the BA-2 manual. Choky omits the motor runs if there is no room. I think he uses Ducati’s. Something like this one: Ducati 4.16.10.30.64 50uf Plastic Case Motor Run Capacitor | Rapid Online
I guess it depends on what new resonant freq you want.
Worse: holidays! 😀
Or, a bit more sincerely: I got a bit quiet because firstly I was messing with my WLS‘s rearrangement (nobody‘s interested in that), and then there’s other, unrelated issues (noisy mac).
Then came old soul, and the lottery…
Inbetween, I was quasi locked out of my atelier due to a job in the mountains, the quasi-inundation of the city, and well, yes, holidays in ticino, with 3 days not raining and 2 days with some sunshine. In other words, we got poured, which is still better than being in greece or so.
Covid is a beast I was able to circumvent quite eary+by pure luck: got shot twice, caliber moderna [emoji41]
- My F4 build (questions, bragging, and other thoughts)
