50w Single-Ended BAF2015 Schade Enabled
Dan, ditch the ammeter in line with anything. If you must test the upper and lower independently to verify proper operation use this attached circuit. Instead of an ammeter, put a bunch of low value power resistors in place of where the "A" is in the attached. I used 4x0.47R parallel for example. For the lower gain test, verify bias voltage is as low as you can get, apply power. Slowly bring up the bias until you measure 28VDC D-S. Connect per the schematic attached, I used this to verify, it works. The circuit as drawn in the begginning of this thread works perfectly, no need to add all these extras. I built the amp exactly, with exception of a pot in the upper Mu, it works.
Sorry about last nights ramblings. I was overtired.
Back to basics. With the ammeter removed the CCS works perfectly with the 4R0 test resistor. I'm monitoring current with Dirk's Ohms law suggestion. Resistor voltage drop (around 1.37vdc) across 0.407 Ohms. About 3.36 amps.
Next step is add the lower half with an external power source feeding the bias.
Going to leave the ammeter out of testing the whole circuit and adjust bias for a Vds of 28v on the lower MOSFET.
Dan
Added the lower half of my circuit with no bias. Blew the 4A fuse and toasted both MOSFETs. I now know my CCS has no design flaws and works perfectly. After reviewing the lower half of my circuit I"m going to do any future testing with two labs supplies. One for the 28V and one for the bias. Not the CCS.
More when time permits!
"The road to hell is paved with burnt MOSFETs!" Dan Twomey 2020
Dan :cheerful::cheerful:
Lower half seems to work relatively well with two labs supplies. One observation. Super sensitive to bias even with ZMs greenies. Prone to thermal runaway if not watched.
More details soon.
Dan
attachment.php
attachment.php
2) The DC Drain voltage of the circuit's gain transistor is temperature
dependent, but it generally should be fairly stable if the heat sinking is
adequate - If it's not stable enough you can put a 5 or 10 watt 220 ohm
resistor from Drain to Source to stabilize it better. I don't think you need
the complexity of a servo.
Tried a 220R5W D to S. It seemed to help quite a bit.
Dan 🙂
Excellent, seems like all is well. Yes, when testing the lower end without the CS, I noted a runaway as well when trying to set the bias, its extremely sensitve. Make sure you note what that bias voltage was, as thats what you'll use when you connect the CS. Now connect it all up, with fuse, and maybe a light bulb in line with your transformer primary....and keep the ammeter away!!
Very interesting.......:scratch2: As part of my pursuit of happiness here I’m thinking of making a ‘stripped down’ PCB that is an exact duplicate of the lower half of the original drawing. This has, and continues to be quite a learning experience!
Dan 🙂
P.S. Many thanks to ZM. I think I’ve tested his patience at times.
The Mighty ZM has 'inspired' me to do some tinkering while I'm waiting for more parts. This circuit also got me thinking on whether or not these 1W or 2W DC power modules are 'easier' or 'cheaper' when it comes to supplying low ma bias circuits...................😉
Dan
attachment.php
Dan, ditch the ammeter in line with anything. If you must test the upper and lower independently to verify proper operation use this attached circuit. Instead of an ammeter, put a bunch of low value power resistors in place of where the "A" is in the attached. I used 4x0.47R parallel for example. For the lower gain test, verify bias voltage is as low as you can get, apply power. Slowly bring up the bias until you measure 28VDC D-S. Connect per the schematic attached, I used this to verify, it works. The circuit as drawn in the beginning of this thread works perfectly, no need to add all these extras. I built the amp exactly, with exception of a pot in the upper Mu, it works.
John,
In future designs I may include the following on certain PCBs.
https://www.mouser.ca/ProductDetail/144-FH-320-NV/
Although I have used ones in the past that have a minature LED that lights
when the fuse blows. I haven't seen any of those yet.
Merry Christmas :frosty:
Dan
