Unusual amp from 1987
If I understand correctly Lender configuration is a simplified version of the added emitter follower between LTP and driver of VAS. It gives more accurate V-to-I conversion from input to voltage amplification stage. Double CCS current drive VAS with emitter follower arrange was used in Revox B285/286 as well from 80's. Its sound was spotless.
See the protective diode and the 2.7 kOhm level shift resistor ?
Joined 2014
This Revox looks interesting. I actually have some SK170 Jfets available :)
Joined 2014
Here is my latest sim.
1) Zener changed to 20V to lower power dissipation on the LTP cascode.
2) CCS changed to BD139
3) current mirror resistors kept at 470 Ohm
4) feedback cap at 10pF - optimized for square wave response
5) Slew Rate 40V/us (Vpp at 48V)
6) in this asc file, gain is set too high - just to be able to get bigger swing to measure SR
I'm sure there is still way for improvement, Maxim - do not order PCBs just yet :)
  • kletzov_1983.hi2.asc
5) feedback cap at 10pF - optimized for square wave response
6) Slew Rate 40V/us (Vpp at 48V)
7) in this asc file, gain is set too high - just to be able to get bigger swing to measure SR
Where is the resistor between the Q12 and Q8 bases ? The denouement must be done !let 10 ohms, but it should stand
The model tolerates.And in iron it is better to be safe
Joined 2014
Will have to try 20kHz sine tests, and then the clip tests.
Also, over the weekend, will try the Revox voltage shifter/buffer, to see how it performs....
Then - version with JFETs in the input might be interesting.
Otherwise have no use for these SK170 devices I have hoarded..
Joined 2014
Nope, here is actual schematic, differs from Egra's.
Rails are 50V, but transistors are different.. Must be 'premium' model.
Update: well, this is not original Revox schematic I guess. No idea where did I get it from...
But it looks like people like it, to re-do it with modern devices and higher power...
  • Revox B285_ORG.pdf
Joined 2014
Found service manual for real Revox 285.
Different transistors. Rails 52V
I guess original printout did not show transistor types or values, and someone added it manually.
Luckily, Q109 is not BC327 :)
