JFET-only Circlotrons without negative feedback
Hi, I have tried to run the last in a LTSpice schematic. simulation and has problems in transient over 0.5V in.
In this circuit, it is necessary to take into account the Idss (Zero-Gate Voltage Drain Current VDS = 15 V, IGS = 0) of each transistor, otherwise the readings will be incorrect.
Idss T7-T10 affects the offset of the SiC JFET gate. I have collected several amps already and they all work great.
From post #200 schematic. I have 0.45 mA in R3, it is ok right? Forget output stage for a while, because I will build a different one. It seems to have a huge gain in LTP. How can I reduce this gain? With 0.1V input I exhaust voltage in, 30Vpp with clipping. Maybe I increase load of 2nd stage?
Upload an image too....
OK changed J2 to J113.
Now I have this pattern as photo on the legs, not good...
Can you check the values (voltages etc) in the attached scheme?
Changed rest of JFETs to J177 and now we are much better. Seems that spice models for 2sk to be wrong.
Anyway, still gain is huge, we can easily work this a full amplifier without pre. I am working to raise up amplitude, so we can have more power on the output.
Second stage is Vbe, correct? I can add more FETs, right?
BTW your LTP stages is beautiful, waiting for the nice SITs to come and I will build it.
