Ultra Simple Class D
how about this tiny
Ok thank you for the driver ossue clarification. It works as you suggested. Also i did a load testing at 45 volts. 225khz freq. Output fets went above 75deg celcius in 2-3mins and output was max 156watts per channel. What would be the problem? Load was 4.3ohms
