Long skinny builders thread
The F1J does not have a bipolar supply like many other FW amps, so each channel has its own secondary winding and its own bridge rectifier and filter caps. The caps across the rectifiers' outputs are additional smoothing caps. The idea is to have a cap as close to the rectifiers as possible.
Thanks, so basically it doesn’t hurt to have this cap on my other pass builds where I use the bridge rectifiers and CRC PSU even though bipolar. Also is the voltage of the cap based on the secondary rating of the trafo?
Some more progress, not sure if this is going to be problematic or not.
Anyway this is what I came up with due to limited space and clearances.
Any suggestions appreciated.
Got the boards wired to the PSU.
So onto the XLR and RCA connectors, wired XLR connectors, just want to know if I have this right, positive to pin 2 on XLR and jumpered to positive on RCA.
Negative to pin 3 on XLR.
Negative from RCA to pin 1 of XLR.
Also, are there any posts about setting DC offset?
Thanks, Greg
