I'm using protection from this post #11209
apex 555 dont have short circuit and overload protection...while your amp is perefesionall and need a perefesional protection too.
plz search in google abuot (ahmed yerli protection)..its complet protection or see below link....i test it with ax17...
Complete Speaker Protection Circuit - Electronics Projects Circuits
or use apex stereo overload protection.
AX14
The AX14 board designed by prasi on post 11462 is current and plays excellent; 100W Ultimate Fidelity Amplifier. I have built it from manufactured boards using the link to pcbway. The other files are there also, for home etching.
Hello to all 🙂
I have one question.
Can be somebody to be so kind and drop me a link for latest version AX14 please or 100W Ultimate Fidelity Amplifier with PCB? I am happy with Toshiba or Sanken versions. All I want is just latest version which I can build.
I got totally lost here 😕
you can replace 2sc5200 /2sa1943 with on-semi devices njw 3281/ 1302, mjl4281/4302, etc without any problems.
if you dont want bjt's, then go for apex mosfet amplifiers like fx-8, fx-8 bimo mod and fh-9 xrk mod, fx-100 etc. and many many more...
If you are referring to the AX14 schematic, it can use many different output transistors. I actually had 2SC5200 and 2SA1943, scavenged from an old amp. Any of onsemi MJL1302 , MJL3281 MJL4281 and their complementaries are good choices and have better SOA.
Prasi posted while I was slowly typing....
Than for the suggestions guys. I have a huge transformer and rectifier board that came out of a Marantz PM80 which I would like to use for my next build. And the 50-0-50vdc Im getting from that is just perfect for the AX14. I guess Im going to have to wait till lockdown is finished to get my parts.
apex psu
hi, i want to make psu from mr mile but i dont have 2 transistors.
any replacement for bc546 and bc556?
5551 and 5401 can be used there?
BC546 CBE --> 5551 EBC
BC556 CBE --> 5401 EBC
For those that have heard the AX14 and the FH9, in your opinion, which one sounds more musical? For music purposes that is. Im going to build either one, was just hoping for a bit of a guide to choose. If parts be a concern, the FH9 would be a better option for me as it doesnt use the 2SC5200 and the 2SA1943's which I have a problem getting
FH9 ok
Work perfectly and Ready to be add to my new A40 Project
That looks awesome and compact. Will it accept only schuter IEC plugs or any IEC sockets like with fuse in-built also possible? Do you have gerber files for this boards to share?
Accept only SCHURTER IEC Plug (D22.1121.1111), which is with fuse and switch, i will post the Gerber file when my A40 project is done..That looks awesome and compact. Will it accept only schuter IEC plugs or any IEC sockets like with fuse in-built also possible? Do you have gerber files for this boards to share?
Sure thanks
Apex A40
Congratulations, I've only been looking at a layout of this for a long time.
It looks great.
- 100W Ultimate Fidelity Amplifier
