100W Ultimate Fidelity Amplifier
@gannaji or anyone: If using a Variac, would you put the bulb tester between the Variac and the unit being tested, or is a bulb tester not needed if using a Variac.
Be safe everyone
MM
My arrangement is like this. The top right hand plug is through the bulb. The bottom two plugs are direct.
All the three plugs are with individual switches.
If this is used before the variac, it will also get tested.
  • mini-ax11.zip
    mini-ax11.zip
Stil14given mentioned the Apex A40 as a hard to beat amplifier
Would it be to much trouble to ask if someone could share the copper, schemtaic and layout for this amplifier?
Hope this helps
Hello to all 🙂
I have one question.
Can be somebody to be so kind and drop me a link for
latest version AX14 please or 100W Ultimate Fidelity Amplifier with PCB? I am happy with Toshiba or Sanken versions. All I want is just latest version which I can build.
I got totally lost here
If I understand, Here are SR200 compliments of Juan Vargas.
very nicely done!..congrats...yes, this one can be used when you already have simple bulk PSU with caps. Even I have such simple PSUs and I could add this regulated PSU as additional.
You could slightly move away the output transistors so they dont foul with V+ and V- faston connectors..
Prasi thanks for advice, but I am going to use output transistor down side board and I m little late for edit because PCB in progress. I have a heatsink 50x80mm there for it's easy fit on it.
Please do not forget to share this.🙂
Thimios Here the file
