100W Ultimate Fidelity Amplifier
Dimbulb tester
Here is a simple circuit. Use 40 watt-100 watt bulb, incandescent type only.
Hello lomdwrrrt,
pdfs for APEX PSU 10R and PSU15.
@gannaji or anyone: If using a Variac, would you put the bulb tester between the Variac and the unit being tested, or is a bulb tester not needed if using a Variac.
Prasi, I will follow your FH9, as I have a set of CFH9 boards I have tried to sell, but may have to build if no response to sale.
Be safe everyone
MM
Be safe everyone
MM
That bulb tester is your single best safeguard to protecting components. I use both every time. Without the bulb tester stuff can burn up at low voltages if something is wrong.
Hard to beat the A40.
hi dear friend.i have aproblem with apex 555 problem.i download many layout of apex555 protect mono and stereo...and made but dont work....now i find correct schematic.
plz tell me apex555 have overload/short circuit protection alone? or need add sepreated overload detector...?
(i buil ahmed yerli complet protection but it have not fast action when turn on power and relay dont act together.)
i want use apex555 pro with all of bjt and mosfet amp like as ax14/ax17/fh11..if it have overload and short circuit to...i know there are many apex protection but i want use apex555.
i wait for reply..with best wish for you.
AX16 is AX14 with add overload/short circuit detection PRO adapter. Reguleted PSU15 is for any amp.
Hello lomdwrrrt,
Hello prasi and Mr. Mile, I've changed power transter with TO-264 package and track change by rotating MJ15030. Capacitor removed from Layout because I have allready simple PSU.
Regard
