Keantoken's Aurum-X 300w Amp with LatFETs
There is also the KSC2690A and KSA1220A.
Just noticed the KSC2690AYS and KSA1220AYS are available again.
160V VCE and hFe > 160 up to 320
Maybe not ideal for an amp running with +/- 80V rails ...
The Unisonic from profusionplc are OK and the tested values look good.
Unfortunatedly the better (higher hFe) 2SA1837LB-TF3T are unavailable. Only the 2SA1837L-TF3T are in stock.
The 2SC4793LB-TF3T are still available.
BR, Toni
P.S.: I have > 2k of the original Toshiba's 😎 And many original 2SK170 ...
Latest render of Aurum-X amp from JS64 Now includes 8x 10,000uF 100v bulk rail caps for CRC, on-board DC protect solid state relay (SSR).
attachment.php
The PSU simulation indicates that we need all of this capacitance to provide 300w into 8ohms. Yes, they are large and expensive. Probably the single greatest cost of the amp besides chassis are the bulk caps.
I am looking at a footprint of 40mm dia x 80mm tall snap-in 10,000uF 100v. These are about $11 to $15 ea depending on model. Exact model still TBD to optimize the best ripple current rating.
If we go with flying leads, a single amp board can sit on the amp floor and MOSFETs mounted on vertical heatsink side. If you wanted a stereo amp, you could put the two amp boards on the heatsink and use direct mounting or flying leads. The two trafos could sit side by side in the chassis middle. It’s flexible.
BR, Toni
[UP.S.: I have > 2k of the original Toshiba's And many original 2SK170/U]!!!
Really a lot!
Prototype Layout Ready for Manufacturing
It's been a while since we have posted an update on this thread, much of it due to everyone's busy schedules and the vastness of this project - requiring a large amount of time to review schematics and double check interfaces, connections, etc. I think we are finally at prototype manufacturing stage though. Here are the schematics for the MainBoard(MB) and the FrontEnd(FE), and various renders of the PCBs and assembled PCBs.
Here is the simplified LTspice Schematic used for the simulation:
attachment.php
The detailed schematics corresponding to the manufactured PCBs are in the PDF's below.
One major design decision was to go with an Antek 500VA or 600VA 58v an AN-5458 or AN-6459, respectively. The 500VA unit actually simulates better if we can believe the spice models that Antek puts out. Not that these transformers that provides auxiliary windings (12v and 18v) which are used to achieve the higher rail voltages for the FE through a half wave bridge. The connection diagram for the various secondary windings must be followed precisely as some phases are flipped. You will have to pay close attention to the PSU topology diagram and use that to correlate to the dot/no-dot leads on the various wires coming from the Antek. This is complicated by the fact that Antek does not label their leads dot/no-dot so some investigative work and experimentation will need to be done with test equipment prior to hooking up at full mains power.
Here is a schematic of the PSU topology to achieve +/-80v for the FE and +/-70v for the output stage:
attachment.php
Here is the top view of the FE PCB:
attachment.php
Here is the assembled FE top side:
attachment.php
Here is the assembled FE bottom side:
attachment.php
Here is the MB PCB top:
attachment.php
Here is the MB assembled top:
attachment.php
Here is the MB assembled bottom:
attachment.php
A big thank you to Keantoken for a super design and very clever PSU.
And a huge thanks and hats off to JPS64 for another superb layout of the highest caliber!
:cheers:
  • Aurum-X-MB_SCH_001.pdf
  • Aurum-X_THT_FE_SCH_001.pdf
Reactions: chermann
That´s right but you´ve also to map 3D components and you know that KiCad librairies are a pain in the A... (I suppose you don´t really know the work load for libraries mapping from Eagle after SCH and BRD importing). Layouting is also way to complicated. But all EDA tools have pros and cons, and yes, KiCad is free and support is not bad at all.
I´m using the older 7.5 Eagle version so ECAD/MCAD is to do manually.:
- 3D STEP download
- STEP to STL using FreeCAD
- STL to COLLADA using Blender
- COLLADA to SKP using SketchUp
- eagleUp_export ulp from Eagle to Sketchup
The newest cloud based version (with great 3D mapping tool) works with Fusion and managed libraries, and yes, sadly it´s not free.
JP
