Mine works very well (Sanwu); what voltage are you running it at? IFAIK, 19VDC (24VDC SMPS) seems to be ideal.
Hello! I am pretty noob with op amps, and i want to modify a 2.1 class d amp with tpa3116d2(the red one with smd op amps).This amps put a lot of high frequenty in my sub and i want to make a cut off frequenty at 150-200 hz, but i have no ideea how. I did not find the schematic for this model.Any ideeas?
The frequency response seems poor at high frequencies.What is it you do not like about the frequency response?
What do you use as source for the amplifier.
What do you use as power supply (voltage and max. power please)?
What is your speaker impedance?
The source is either a Pi 1b and Pi core player feeding into a PCM2704 usb Dac. Or Thin client, dual core, running Daphile into the same PCM2704 Dac.
I have another Dac, a ES9018k2m SA9023 usb and that is worse on all amps I have tried so far.
The rail voltage is 12v up to 3.5 amps. and the speakers are sony 4 ohms. Not special in any way.
I complain as when I run either input to a NAD C326BEE amp and same speakers the high frequencies are acceptable to me for a workshop system.
I have also compared the same inputs and speakers and rail voltage with this ebay item no
192431666420 and it was better and acceptable.
Sorry for the late reply. Thanks for a detailed reply that helps us understand the circumstances.
From what you mention, I see nothing that necessarily causes poor high frequencies.
12V supply is not enormous but if you still have poor high frequencies at low volume, that is not the reason. I have a TPA3116 amplifier looking very much like the second one you mention but not the one causing you problems. The difference between the two is that the second has two TPA3116 chips while the first only one. Also, the second has better filter chokes is my guess.
If you really want to spend time and money on improving such a cheap TPA3116 board, change the filter chokes as the first.
I bought the dual TPA3116 and the single TPA3116 and much more^^ But best are this. I also bought a cheap dual TPA3116 with false outpute chokes. Both are good. The dual TPA3116 existe in a enhanced WIMA version. I put both links.
TPA3116D2 DC24V 2x 100W two-channel stereo Class D digital audio amplifier board
AIYIMA Professional Mini Amplificador Audio Amplifiers Board TPA3116 2.0 Dual Chip Digital Power Amplifier 100W For Home Theater
TPA3116 D2 2x50W DC10-25V Stereo HIFI Digital 2.0 Audio Power Amplifier Board G2-006
How does it sound?
I think the second amp. is also single chip but is two channel.
The only reason to modify it is I have it and am using it at the moment and its not as good as the other amp I am also using.
I also don't want to spend any more money I am not mean but have to stop somewhere.
That depends of the signal input, Jazz sounds fine, Tekkno awful😀
i need HELP. my YJ blueboard tpa3116d2 with 24v 10amps lpsu keeps getting cut out even in moderate listening level.
What is the impedance of your speakers?
Do you have the possibility to try it with a supply voltage of 12-19Vdc? (moderate listening level)
tested it out with these
4 ohms An externally hosted image should be here but it was not working when we last tested it.
6ohmsAn externally hosted image should be here but it was not working when we last tested it.
8ohmsthe amp in question.Facebook
i ordered a dc-dc regulator few days ago. it arrived yesterday. as we speak i dialed it down to 19v and its still getting cut out. my other tpa31162d with 24v 6amps smps doesnt have this issue. sorry for not providing useful innfo. as im not that knowledgeable when it comes to class d or electronics in general.
Many thanks for the nice photos. They seem like nice speakers.
The reason I asked for the speaker impedance is that very low speaker impedance requires high currents and that may cause the over-current protection to be invoked and help on heating of the chip such that the temperature protection may become active. Your speakers do not have an impedance below 4 Ohm which is fine.
I asked you to try the lower supply voltage (12V-19V) because, from my own experience, the TPA3116 starts becoming warm above 19V supply and that again may affect the thermal protection. Also, 24V is close to the maximum supply voltage of 26V such that the over-voltage protection may activate if the 24V supply starts swinging (not oscillating) which is usual with a varying consumption. You tried the 19V and that did not help. Had you used batteries as supply, the under-voltage protection may activate because some batteries react slowly.
So, lets check the input DC-level protection. Do you have two resistors with a value between 2K2 and 10K? If yes, connect these two resistors across the amplifier input (signal line to signal ground) and try playing again using your 19V supply + 8 Ohm speakers.
As you can see, there are many "protections" integrated in a class D chip and we need to see if any of those disturb operation.
Total noob here...
I'm about to assemble my very first amp. My objective is to try and make a decent and CHEAP amp while my main amp is out for repairs. The board (XH M572 - see pic) is built around the TPA3116D2 chip.
It should be delivered in a few days along with the connectors (speaker, RCA, power). I intend to power it with a laptop power supply I have lying around (12V, I think). While I was researching on how to go about this, I came across some issues that I hope you guys can help me with.
1. I intend to house it in a wood cigar box which I already have. Should I line it with aluminum foil/copper/etc. as some threads suggest (with differing opinions on what material to use, of course)? I happen to have some aluminum tape. If this is advisable, should I line the entire interior (bottom, sides, top) of the wood box?
2. Internal Wiring (Power) - Can I use 1.6mm/16AWG Solid Copper Wire (THHN) to connect the board to the power supply socket?
3. Internal Wiring (Signal Input) - The board comes with a 3p Audio Cable (R+, L+, Common Ground). As I will be using Female RCA Jacks/Connectors, I intend to cut off the connector on one end of the cable to solder directly to the jacks. The R+ and L+ shouldn't be a problem. What's the best way to to connect the ground (as I will only have one wire). Can I just run a wire to connect both grounds and solder said wire to the exposed end of the 3p cable?
By the way, I intend to use CAT5e cable for this. how many twisted pairs would be recommended?
4. Internal Wiring (Speaker Output) - I again intend to use CAT5e cable for this. how many pairs is recommended? Or would I be better off with using speaker cables instead? I also have some THHN Electrical wire. Would that be suitable to use as well?
Again, apologies for my noobish questions. I know I shouldn't expect much from this project with the money I've put in (I'm around $12 into it) but I really want to get it right the first time.
P.S. I intend to get a better power supply if I get the amp to work right. Aside from the power supply, would replacing any components on the board itself yield improvements in the sound?
Reducing the gain is well worth doing. Involves removing 1 resistor and replacing another, as long as your confident soldering small smd components.
Depending on your input you might run into earth loop problems. I did when fed from Daphile music server and needed a usb isolator. Something like
eBay item number:
283106862763 or similar.
eBay item number:
Could do with details for this.Reducing the gain is well worth doing. Involves removing 1 resistor and replacing another, as long as your confident soldering small smd components.
thyristor44
Reducing the gain is well worth doing...
Will probably look into that in the near future. For now, more interested in just getting the thing up and running.
Depending on your input you might run into earth loop problems...
Will be hooking this up to a USB DAC/Preamp via RCA. It seems the board has its own ground line (common) which I intend to connect to the RCA connectors which have their own respective ground lines (isolated from the case via spacers).
Total noob here...
Most start like that.🙂
Seems OK.
Laptop supplies are often 19V and that is fine for the TPA3116.
If you can make a conductive lining where all parts of the lining are electrically connected together it leaves you the possibility of shielding. Shielding may improve noise performance and reduce EMI.
Yes, if you can manage to drag the rather thick wire around in your box and solder it to the terminals.
I do not understand. A sketch?
CAT5e cable is not particularly suited. Can you get your hands on audio cable - 2 wires with shield?
CAT5e cable is not suited for speaker use. Use speaker wire.
Clever to ask (and read) before doing.😉
Listen to advise from others. I have no experience with that board. Add some power-line decoupling capacitance.
Seems OK.
Sorry, got mixed up. I have a 19V laptop power supply. 🙂
Thanks for this! So I guess I'll be lining the entire interior of the box with the foil tape. I know this isn't ideal but I'm pretty much trying to work with what I have on hand. Will check conductivity on all sides.
Haha, yeah, the wire is pretty thick and hard to manipulate but I'll give it a go. In case this becomes too cumbersome, what size of wire would be advisable for this application? Would it matter if it were stranded or solid core?
Kindly disregard. I saw an example of this on another thread.
Ok, will do. Thanks!
Ok..... So um.... is "audio wire" different from "speaker wire"? 😕
- Class D
- TPA3116D2 Amp
