Building your own amplifier enclosure
here's the last chassis i build from scratch (besides the front panel that is from modushop). build cost was about 130€ inkluded Paint.
Anodizing is pretty simple.
The "nasty" chemicals are:
- Sodium Hydroxide (drain cleaner) 2% solution (i.e. a couple of large spoons per litre)
- Sulfuric Acid for the anodizing bath 10% (mix battery acid 1-3 or 1-4 in water)
Ah, I was thinking of chromic acid which is used industrially, very nasty and carcinogenic, H2SO4 is much safer.
Titanium anodizing I've done with borax which is even safer.
Looks tasty thimios. As regards painting do you know to use etching primer on aliminium? It's also a good idea to get the paint and metal at the same temperature and practice on a scrap bit of ali first. Obviously all metalwork has to be clean. Lastly it's easier to get a good finish with matt black rather than gloss.
Andy.
Andy.
Look Andy, the top and bottom aren't aluminium.
They are steel 3mm.
They are painted using primer and then paint.
Frond and rear are 4mm aluminium.
My plan is to anodize and paint this.
I use a mixed method,as i can't buy clear, not scratched aluminium.
I will anodize the rear and frond and then i will paint with a mat black spray.
Some pictures with the progress.
Some of my boxes.
Reactions: ziffel
Hello!
I'm building 6 monoblocks right now, and after thinking about what boxes to make, I decided on the following option.
From the sheet metal, I built the internal skeleton of the amplifiers, making sure that the power supply was separated / shielded / from the circuit boards.
Since the monoblocks will be in bridge mode, there will be 1 radiator board on each side and the power supply in the middle.
I know it looks pretty ugly, but it's the internal skeleton of the amplifiers, the supporting structure, and you won't see any of it in the final version.
When completed, there will be facade panels installed around the skeleton.
The topic is very interesting and contributes to the exchange of experience.
Greetings!
Hand made all as my friend Thimios.
Mimesis 9.2 clone steel plate 4 mm -USSA -P3A.
