diyAB Amp The "Honey Badger" build thread
I have another question to those who built the amp: where you able to use electrolytics of bigger diameter and lead spacing than the ones stated in the BOM, and vishay dale rn60 resistors?
Cant't use rn60, I use rn55 and there are 0.6w that can fit, for example vishay mrs25 , te lr1 series. You can buy from mouser rs etc. For electrolytic, I user the one that fit pcb, panasonic fc are small enough.
this is my completed HB amp..
Tony,
I used pre-packaged bridge rectifiers as well, mine are in a different package though.
Did you use anything between the "mounting bar" and the transistors to help disperse torque? I'm curious because I was going to do something similar to this idea. I'm still undecided on that for now.
Tim
as you can see i used an angle bar 10mm x 10mm x 2.5 mm so that torque should be evenly dispersed,
Built in protection would be nice, especially for first time builders like myself.
This aside, I guess with all the different variants of badger's out there it would be hard to make a "one size fits all" protection without increasing the footprint significantly.
I plan on going the 21st century route myself, it's quite interesting/advanced set-up. I was reading the thread a year or two back, and it is a very impressive protection system.
