Current feedback Mosfet Circlotron
1) 600 Hz, 2) 6 kHz, 3) 32 kHz, 4) 60 kHz.
What is the peak voltage at clipping?
The second time to bring to clipping failed. Blown IRF1010E and fuse.
Before clipping, I saw excitation on an oscilloscope. The amplitude is 15 V. The load is 8.2 Ohm.
Replaced IRF1010E, it became bad. The amplifier was excited under load. Replaced C3, C4 - 39 p, C5, C6 - 150 p. It did not help.
Installed 30 Ohm in Gate IRF1010 and it got better. Tomorrow I will increase to 100 Ohm.
Seb,test your amplifiers for excitement. Maybe this is so bad only in my amplifier.
Reduced the supply voltage to 28 V.
Reduced the resistors R17,18,19,20 to 270 Ohm.
Clipping starts at 25 V. One division on the oscilloscope is 5 V. The load resistance is 9 ohms.
RMS power - 25x25 / 9 = 69.5 W. Correctly?
It is also necessary to reduce the resistors R8, R9.
P.S. Now IRF1010E can work.
