Acoustic Horn Design – The Easy Way (Ath4)
Yet another horn (measured). It's around 12" in size, 100° coverage, somewhat bigger A9, 18Sound NSD1095N.
Made with Ath4. See how easy it is... 🙂
Reactions: Arez
On behalf of Michal, who did that WG and measurements, intended just as the first proto verification of WG/driver combo.
Measurement conditions:
- WG was standing on the box of the same width as WG
- mic distance 1m
- measured indoor
- smoothing 1/12
- gating 4ms
Have you put any thought into creating a DXT-style diffracting waveguide for the SB26ADC? That's exactly what I'd like to do but if you've already done it, I'll just save myself the time...
I have a nearfield monitoring application where I would like the full spectrum off-axis response up to 30 degrees to be as close as possible to the on-axis response. The DXT tweeter does a great job with dispersion up to ~20 kHz but unfortunately does not have good distortion performance below about 1.4 kHz, which is also what I need.
I could probably throw together a waveguide for the SB26ADC in about one hour, using the methodology here :
3D Modeling Tips and Tricks
But you'd need a way to print it.
Also, I've generally found that any dome over about 3/4" works poorly on waveguides, due to the geometry. (The tip of the dome is too far away from the edge of the dome, causing a high frequency dip as illustrated here : David Ralph's Speaker Pages - Projects )
But if you have a 3D printer, might be worth a shot.
I could get someone locally to do it for me, or heck, bite the bullet and buy a printer for myself.
Seas uses a 1" dome for their DXT, and the response comes out looking perfect. Perhaps the protective mesh helps?
