The diyAudio First Watt M2x
Wohoo! My first Papa amp is putting out some tunes. Better sonic analysis only after my hype has settled down a bit...:D
Thanks to Mr. Pass for publishing these gems and to Mark Johnson and 6L6 for the guides and instructions.:worship:
I attached a few pics of my build. The case and trafo are both from Toroidy.pl. The total cost was approx. 800€ with some extra resistors and other minor parts. I installed the slow start and speaker protection boards too.
Joined 2016
Well done and Nice build! Enjoy the music!
Case from toroidy.pl? Their front panels has four screws. How you disappeared it?
Very nice build Morde!
So....what are you building next? :D:D:D
I did drill the sinks according to the diyAudio UMS so I'm all set for future endeavors too...;)
One issue has arisen in a form of hummmm/buzzzz...:mad: I'll plug in a scope to the speaker terminals to see is it a 50 or 100Hz disturbance. Or something else.
The first remedy that came to my mind is to move the speaker return wire from amp pcb output ground to PSU board's ground.
Ooh, this is a nice tidy build. COngratulations.
What did you use for output transformers? I've been considering this as a next project, but didn't see a good US source for the edcor transformers in the parts list.
