100W Ultimate Fidelity Amplifier
Joined 2013
hi mr mile...my prroblem about fh11 be solved.with replace 150R with 470R.fh11 is good an stable.
i need a grafic equlizer/tone control with bass booster/fast speaker protection.
please tell wich is best.
best regards...
This 150r to 470r stopped the power-on noise? To clarify, you changed R9 from this schematic/board layout? I am having similar issue, but negative DC for about 1-2 secs, pulls the woofer in. Hardly any real noise, but if I can avoid I would like to.
AX14 questions
I obtained some boards from PCBway as per this post https://www.diyaudio.com/forums/sol...mate-fidelity-amplifier-1044.html#post5479358
Has anybody build from this PCB? I have found the matching BOM and started a shopping basket with Mouser.
prasi, I see you were getting components together a while ago, did you complete the build?
Regards PSU, I have a 300VA 30+30 toroid I am intending to use, that suitable (expecting around 100W output).
Its an interesting and lengthy thread but the number of variants has been somewhat confusing!
Thanks, Chris
i can not kill popup noise.but when replace 150R/R9 with 330R or 370R mje350 and 2n5551's dont be hot....and circuit be stabl.but with 470R sound be very bad...because drivers can't work properly.you use 330R.
i dont know that how kill popup noice...mr mile just can help us.mr mile if you hear me heeeeeeellllpppp us please.
