Looks like it is just fine to make both feedback resistors 27K to lower the gain to 2X.
I want to thank you too. Having big horn speakers it benefits me having less gain.
Received the GlassWare audio bipolar supply today and they did a fantastic kitting job. All parts individually bagged and labeled.
6L6, looking at your post 235 I think you chose the 1 ohm resistor for R3 in the CRC filter. Is was thinking of using the3.3 or maybe the 10 ohm resistor because the total current is something like 60 mA. Any thoughts?
Go with what the manual suggests for the current. I didn't build the board in the photos, John sent it to me already built.
Whoops, I just duplicated your pic! What should it be? I really couldnt tell what to do from the instructions...I used the Antek transformer you suggested.
Russellc
I just through together a supply that I had laying around. It’s very compact and sounds pretty nice. It’s based on dual TPS7A3301.
https://www.diyaudio.com/forums/ven...vailable-bal-bal-se-se-lpuhp.html#post3516741
For those that are going this way, it is a really nice kit. I was missing a couple of parts which was frustrating. I emailed that info in but received no reply. Fear not. Within a day or two I got a shipping notice, and next day or so had package with those parts.
Lesson is, he is listening and will send any parts that are missing. This is the 3rd power supply I have ordered from this outfit. Two for a couple of BA3 FE preamp builds, and this one. First one that was missing anything, and it was quickly taken care of!
Russellc
Damuffin - Looks fantastic!! Breadboarding a project is a great idea, simple to try, simple to work on if you're needing to tweak it.
PSU - Yours from The Wire is perfect. It's a quiet supply and small, the Burning Opamp is quite tolerant of supplies, I've tried 3 so far all with great results. Find a cool chassis and box it up!
Might want to add a potentiometer...
- Wayne's BA 2018 linestage
