Wayne's BA 2018 linestage
To all who have the kit of parts that I made -
I supplied the wrong capacitor for the lead/lag network (C4). In the kit is 330pF where the schematic and PCB are both labeled 220pF. (Thanks to Gary S for bringing that to my attention 🙂 )
The good news is Wayne has tried and tested this value in the circuit and has declared it fine. No measurable difference in the audio band, and the only changes were minor and up near 5MHz.
Sorry about the error, but it looks like the audio gods are smiling on this project.
Carry on and build amps.
(Preamps, more specifically...)
Insignificant difference, I measured around 330pf with my meter and installed them anyways in 220pf spot without giving a second thought. We are dealing with pf.
I have my headphones on listening to it this very moment I'm typing. (The point of the big outputs being they have enough power to directly drive headphones.) ((And whatever insane cable runs you could possibly envision))
Sounds wonderful!! Photos soon.
So I took the chassis with the BA-3 Preamp and removed the gain stage and replaced it with the purple boards.
These have the alternate outputs, in the TO-126 package, and have plenty of drive for my low-impedance headphones. PSU voltage is high enough to drive high-impedance phones as well.
attachment.php
The BA-3 preamp. Taping the switches and attenuator up as work is done on it. Yes, the transformer is enormous, it was intended for a chipamp project that never happened. It's super quiet and was the right voltage. And was on my my shelf... 🙂
attachment.php
Installed with the purple boards.
attachment.php
attachment.php
The headphone jack is a switched type, it will pass through the signal if no plug is installed, and send the signal to headphones if installed. So the jack is wired first on the output of the boards, and then output RCAs are further downstream.
I'm going to install the Broskie regulator (and a more reasonable transformer 🙂 ) next and take more photos of the connections.
