Current Feedback Amplifiers, not only a semantic problem?
If both input ports on a VFA are hi-z, how does a low feedback ratio give it CFA COD behsviour? It doesn’t. It’s just a badly comp’d VFA.
Sorry, I don’t see CFA = VFA and never will. Two separate topologies that have some behavioural overlap under certain conditions wherein a CFA can morph towards VFA behaviour but nothing more.
Andrew, you don't have to admit CFA=VFA, and neither do I. You already admitted everything it is to admit about: "two separate topologies...". Glad you departed from the (wrong, in my opinion) idea that CFAs are anything else but a clever circuit topology, with special properties.
Please don't (once again) conflate small signal and large signal properties of any circuit topology. I was discussing mostly the small signal properties of CFAs and VFAs, and proved that they can be mathematically deduced using the same general feedback formalism that is serial input, shunt output.
COD is a large signal property and has almost nothing to do with the feedback configuration. As mentioned multiple times, COD can be rather easily implemented in a VFA topology (be it your next long tail pair VFA, or any other input stage configuration. It is true that COD comes natural to CFAs, that some COD solutions for the VFAs are not necessary easily integrable, and, given an idle power budget, the CFA COD certainly cannot be surpassed by any VFA COD trick.
Re in CFA’s is usually small compared to Rf and Rg because you want high gm (discrete power amps may be a special case for other reasons). Rf is used to compensate the amplifier and in IC types, you have no additional capacitance other than whatever is on the chip hung off the Tz node in the interests of preserving bandwidth. This is not the case with a VFA ( power amp) where you degenerate the LTP pair to ensure front end stage linearity. In an IC VFA, MC is used with the OL pole set at a few Hz so degeneration is not often used ( noise reasons as well).
CFA is Unbuffered VFA, CFA specificities are that open loop behaviour depend of feedback network and one pole less than VFA.
Not true. A CFA has two poles, just like a VFA. Ignore the IPS pole, because it is usually very high for both topologies. The other two poles are the TIS/TAS and the OPS (which is usually the one that you have to take care of with compensation).
A CFA is not an unbuffered VFA. The operating principles are fundamentally different as Chris and numerous others have tried to explain. Current into the 2nd stage is steered from the LTP current source in a VFA. In a CFA it is controlled primarily by the value of Rf.
Here are the gain/response plots for a VFA.
You've totally lost me on this.
I've made my understanding of the two topologies clear and am quite aware of the differences between small signal and large signal behaviour. That you have derived the small signal properties using two port analysis is great but not new - I think its been done numerous times previously in various applications notes and academic papers.
I don't see CFA's as anything special - I agree its a clever topology that simply does some things in its native state (slew rate and bandwidth primarily) a bit better than VFA, but there it ends. I have never claimed anything else (I've designed and built both . . . )
How about simply graphing the ratios of the inverting input voltages to their currents? They're identical. Enough proof?
Inverting input impedance. Great !
It is not the criteria.
OK, you've said it. I'm done here. Apart from all of the rest of it, the rejection of the obvious, inferring that I claim that DC current flows through the feedback network, if now MDIT is being questioned, there really is no basis for further discussion. I'm not going to take the time to even try to acquaint you with why you should accept it. Perhaps you and forr can form a study group to evaluate it.
Don't understand what you say about DC current flow.
Let me remind you that you sent a MDIT implementation sim that didn't work at all, and you didn't know it didn't work.
Try to make something working, and test it.
Hi Chris, all,
Thanks, CPaul, for raising it; it looks like we now have a good reason to convert to the VBIC model.
IH
Ian, thanks for looking into this. The results are worrisome for our general use of LTSpice.
Regardless of the transistor spice models we use, the Ebers-Moll/Early equations and the Hybrid Pi model support the existence of the small signal effect I was discussing. It would surprise me if the non-ideality of these were so extreme as to make the effect itself questionable, but what appear to be the relevant issues are the values of various parameters and the extent to which the effect occurs.
Then you need to be clearer about what you're talking about. You would tell me what it isn't, but not what it is?
Then I don't understand your problems with my original comment.
Let me remind you that I corrected it by adding 1 Gohm resistors across the current sources and you have yet to reply to it.
I said step the gain - so by that I mean at say 2 or 3 dB intervals and plot them on the same graph.
I am willing to bet that at very low gains, the square wave response will be bad - overshoot, maybe ringing. To get rid of this, you will need to adjust the comp at very low gains. It would then be GBW dependent - so nothing to do with CFA like behavior.
Sorry, in the message quoted above you shifted liberally from small signal behaviour ("increment the gain...") to large signal behaviour (square wave response and COD), hence my confusion.
If you agree that CFAs are circuit topologies with series input, shunt output feedback, with some specific small and large signal properties, then indeed there is nothing more that you need to accept. I can't stop noting that your position regarding CFAs has softened considerably since this crazy debate started and I can only hope I contributed a little to this 😀.
My only "problem" is with prof. Franco Closure statement:
Using two-port techniques to manipulate a CFA circuit into a series-shunt configuration is a popular alternative for the paper-and-pencil calculation of the loop gain T, but it fails on other vital issues, such as the correct representation of the type of feedback actually taking place.
which is, to me, wrong. I went through the references he provided and I was unable to find anything supporting "two-port techniques to manipulate a CFA circuit into a series-shunt configuration (...) fails on other vital issues, such as the correct representation of the type of feedback actually taking place" but then again, I'm not in the position to debate with a renowned authority, so I'd rather leave it there, and agree to disagree on this.
The GBW independence in CFA is small signal behaviour. But using a swuare wave to show gain peaking and response anomalies is also done in the small signal regime.
COD is large signal - agreed - but I was simply pointing out to (Herve IIRC) that low closed loop gain 'COD like' behaviour in a VFA is nothing to do with CFA COD and everything to do with a sub-optimally compensated amplifier that will oscillate.
"If you agree that CFAs are circuit topologies with series input, shunt output feedback, with some specific small and large signal properties" - yes, I agree.
However you should emphasize you can do the same with a VFA because you are talking here about the canonical feedback forms which apply to both CFA and VFA. This is a point that kicked off this whole thread because people (forr et al) confused 'current output' with 'current feedback' - and I pointed out waaay back in the forst CFA vs VFA thread that they were not the same and the canonical feedback forms make this very clear.
The CFA trick is however that its possesses COD (large signal behaviour) which a VFA in its classic guise (LTP, MC compensated, no tricks) does not.
Nope. Try to simulate in Spice the square wave response from an AC (which is linear small signal) simulation. You can only do a frequency response, but a frequency response peaking may or may not be related to a significant square wave (large signal) overshoot.
To determine the square wave response you need a Transient analysis in Spice, and that's a non linear, large signal, analysis.
Sure.
It is easy to see that I(in-) = I(Rg) - I(output through Rf) . Are you among those who say that there is no current feedback because the electrons flowing through the input stage do not flow through the output stage? If so, your claim leads to the conclusion that negative current feedback is impossible, as I have made clear in prior posts. Are you willing to state this? Please see the attached which better describes this point.
In many posts to you, I have carefully written "signal current" to exclude DC bias current. In this case, I was trying to be absolutely clear about the relative directions of current flows. Are you trying to play "gotcha" here? Do you really believe for a moment that I was implying that input stage DC bias current always flows through the feedback network? Give me a break and drop it.
I have no problem with the not DC current electrons flowing.
Yes, and I have no doubt it works fine.
I take it we are talking about the same thing here . . . small signal 1 to 2 volts, large signal 70 to 80% of the full rail swing. Nothing to do with AC or transient analysis. (You can always try a Bowles stability test if you want to combine the two - quite useful.)
Fact is the square wave response of an amplifier (small signal) can tell you an enormous amount about the system's stability and/or about its frequency response - think about an RIAA amplifier for example in the latter case where you can use square wave testing to quickly and accurately test for response conformance. In a straight amplifier, for audio applications, I'd expect low/very low overshoot and flat response within the audio band.
Small signal (1~2V) frequency response of a CFA will show GBW independence wrt to gain stepping. If it shows peaking, the designer better understand why and make sure its tolerable in the application. Nothing to do with COD - Herve made that claim IIRC - and there I agree large signal transient analysis is what is required.
I take it we are talking about the same thing here . . . small signal 1 to 2 volts, large signal 70 to 80% of the full rail swing. Nothing to do with AC or transient analysis. You can always try a Bowles stability test if you want to combine the two - quite useful.
No I don't think so. A small signal analysis (or simulation) assumes linear models for all devices, while a large signal analysis should consider nonlinear models for all devices (where applies).
A small signal analysis would not care if you apply a 1kV signal at the input, the result will be a scaled up version of the 1mV input.
I spoke of IPS pole, one less device (feedback network buffer), one less pole.
Why don't you see that ?
Firs amp schemes were single device input, with feedback on the -cathode, emitter, source- now named as CFA. VFA appears by adding a device to have a LTP or others, and a buffered feedback network.
We are saying the same things here. Read my previous post.
As I said, for the purpose of a small signal analysis, the input signal level is irrelevant, specifying it ("1~2V") confuses me.
Perhaps what you want to infer is that a large signal analysis (using non linear model), with a input signal level -> 0, should converge to the small signal analysis.
BTW, "1~2V" is a pretty large signal for "small signal". The convention is to use signals that are <<kT/q at every node of the circuit. Could be ok in some cases, but I would not always count on that.
"Why don't you see that ?"
I could ask you the same thing Herve! We have been around and around with you and forr and you still cling onto your 'understandings' of how these things work that are manifestly wrong.
They don't behave the same.
They don't look the same.
Academics and engineers who have worked in the field for decades tell you they are not the same and you need to go back and re-evaluate your understanding
Your response? Ignore them and just repeat your dogma.
"Firs amp schemes were single device input, with feedback on the -cathode, emitter, source- now named as CFA. VFA appears by adding a device to have a LTP or others, and a buffered feedback network. "
Adding a 'buffer' to a single ended amplifier does not make it a VFA. Likewise, removing one half of an LTP does not magic up a CFA.
See CPaul and Hans Polak's analysis. You keep 'modifying' circuits to try to support your theory and it does not work.
