H2
A software that also shows the residual:
DiAna
There are two examples of my latest toy. A DEF amplifier with UJN1208K and IRFP9240. The Vout are 2.55Vrms and 8.29Vrms @ 8Ohm (maximum allowed by the measurement system). I used an EMU1212 with Pete Millett's sound card interface.
I agree! When using LTSpice and viewing the harmonic distortion components the 2nd harmonic will be +45 degrees relative to the fundamental for a perfect neg. phase 2nd harmonic.I've used this method for tuning my F7 approximation and my ears like that setting more than all the others I have tried.
I'm not following your line. Make the fundamental test frequency at output display phase positive relative to the input. Say use 1 KHz to test. Then when measuring, dose the second harmonic have any phase rotation relative to the input? Is it closer to 180 degrees from the fundamental (negative phase) or is it closer to 0 degrees (positive phase)? That sums up my concerns. If both fundamental and second harmonic are negative relative to the input when starting that means to me that they are positive phase between both fundamental and first harmonic and flipping a speaker cable changes nothing between them.
Look at the picture in post #156.This shows neg. phase H2 (lower trace).Look at the fundamental where it crosses the x axis going positive and take that as your reference (0 degrees).Now look directly below that point to the H2 trace.You will see it crosses the x axis ahead ie: + degrees ahead of the fundamental by approx. 90 degrees referenced to the H2 which is +45 degrees referenced to the fundamental.LTSpice shows harmonics referenced to the fundamental,in my sim I use 1khz as the fundamental.So if I see my H2 is +45 degrees that is a perfect neg. phase H2.Nelson explains neg. phase H2 as having a negative peak at the same points along the x axis as the fundamental has its positive and negative peaks.
I am looking at the picture in post #161 and I do not see a 45 degree offset.
No there is a little more than 45 degrees but less than 90 degrees,I said perfect is 45 degrees,its still negative phase H2,there is a range.
When I say 45 degrees is perfect I mean the H2 is 45 degrees referenced to the fundamental which is 90 degrees referenced to H2.
Both the Nutube and the H2 can be adjusted for positive or negative
phase H2.
My definition is: Negative peaks on harmonic with any peak of fundamental
equals negative phase. Positive harmonic peaks with any fundamental
peak is positive phase.
And once again, if the circuit is inverting, then the harmonic phase inverts
if you correct the absolute polarity after the distortion generator.
:wiz:
Some of Nelson's amps produce mostly 3rd harmonic. Is there a preferred phase of H3?
The Amp Camp Amp inverts the signal and produces an in phase H2 at it's output. There is an option to convert a dual channel ACA to single channel bridge drive. The way this is implemented on the DIY Audio store's kits simply uses a resistor to reduce the gain of the 'slave' side to unity. What does feeding + phase H2 to the second channel do to the output? Is H2 canceled or reinforced ?
Isn't there a better way to create bridge drive ? When I measured the ACA's distortion in bridge mode I simply used the balanced output of the AP system.
You almost always see H3 aligned to form slight compression on peaks
of fundamental, for fairly obvious reasons.
Rarely you will see H3 consisting of slight expansion at peaks. One can
speculate that maybe this leads to more dynamic sound.
Amplifier example was the Stasis 1, where at modest power levels the
H2 has expansion characteristic.
You might want to use a transformer for another reason as well:
The H2 circuit is only good to a couple volts output. If you want more,
the transformer could give it to you. also handy for performing phase
inversion so as to correct the phase inversion of the H2 circuit.
:wiz:
It would be a good idea to measure H2 of the speaker output. It seems like actual H2 we're hearing is heavily and unpredictably affected by the speaker network design, unit H2, and (possibly) time alignment.
Is this another reason why many SET guys love FR?
Showing plot is 2 way BW3 @810Hz, driven by AJ.
No H2 - positive H2 - Negative H2
Thank you. That conforms to findings of Eduardo de Lima of Audiopax. The measurement shows 110dB, is it at normal listening or a rather loud level? I think measurement around the 1W listening window, perhaps at 85 - 95 dB, is the most important. 🙂
