The Aleph Design Reloaded
I designed a PCB to build an Aleph 3 clone. I transcribed the schematic Nelson posted early in this thread to DipTrace, which is my preferred software to design boards. I used the "Check Net Connectivity" and "Compare to Schematic" features in DipTrace to verify the PCB layout. No errors were detected.
I built one PCB and connected it. I can hear the music playing but it is distorted.
I measured only 0.31V across the source resistors. Removing R113 the voltage only increases to 0.42V.
The measurements I took while R113 (56K2) was still installed:
V+ +23.4V
V- -23.4V
Q105 Vce 3.8V
R106 5.1V
R108 4.3V
Z103 9.1V
Obviously I made a mistake somewhere, but I just can't find it. I have compared the transcribed schematic to the original, verified all transistor footprints to make sure they match the datasheets. As mentioned above, DipTrace does not indicate any discrepancy between the PCB layout and the schematic. Maybe the schematic has an error and I just can't see it. I am hoping somebody can help me spot it.
http://www.diyaudio.com/forums/attachment.php?attachmentid=663825&stc=1&d=1519168913
DC offset is 0V. The input pair is tightly matched and I used a 500R trimpot for R108. Is it cheating? :)
On that subject, you once posted that to trim DC offset you preferred adjusting R106. Could you elaborate on that? My first impression is that changes to that resistor would affect Q101 and Q102 equally.
Official Court Jester
Joined 2003
btw. you can trust me ......... or you can trust in some good schematics ....... result will be the same
regarding Papa's schematics ....... he used to be lazy sometimes , skipping few dots here and there
who knows , maybe it was deliberate , you know - pedagogy reasons
:rofl:
see attached schm ........ as far I remember - there was no mistakes , and there are plenty of nice details
  • Aleph30 by Algar_emi.pdf
:rofl:
I recall one (more?) of the original Aleph schemes having a fatal error :eek:
Boy, that drove me nuts :yes:
The good news is that Zen Mod confirmed my schematic transcription is correct.
The not so good news is that the change he proposed only moves C102 negative connection to the inner side of the output current sensing resistors, effectively bypassing the equivalent 0R1 series resistance.
The bad news is that after hacking the PCB to implement the change, nothing really changed. The bias is still low, which I believe is causing the distorted sound.
