Studio Reference Amplifier
I have found two different speaker protection circuits done by Apex. Which one to use with SR150? Is it possible to use them with another amplifiers - my Sony receiver, for example?
It is an electronic (non mechanical) switch that is self powered (from the input power supplied to the speaker).
It works by opening the speaker circuit when an error signal is detected.
Sorry wrong explanation.
This one inserts a short into the speaker feed to protect the speaker and destroy the damaging amplifier.
SR200 Pro Adapter
ApexAudio[/QUOTE said:
sir mile,
i want to add limiter(NSL32)
and pro adapter for SR200 which one will you recommend to be used in DC555 and H900 Protect circuits i like to often use these relay type protect.
thanks
regards...
