no pic.A quick update to my F4. An easy access power switch! My wife was really tired of having to reach around the amp to turn it on and off and ordered me to install an "easy switch"! 😀😀
can you upload to diya, pls?
I've done that , on bottom , slightly higher feet and white led glowing down
Same here 🙂
Switch is still on the back, but LED is on the bottom. Added a piece of perspex to guide the light to the front.
Just don't have the tools (and the guts) to drill the front plate.
Thx ZM. I still can't see the original image for some reason.
Masantos.A quick update to my F4. An easy access power switch! My wife was really tired of having to reach around the amp to turn it on and off and ordered me to install an "easy switch"! 😀😀
Attach pictures using the forum's ATTACH
How to attach images to your posts.
In the ground next to the toroidal transformer you can see an Arduino Nano, where the two 1-Wire temperature sensors (18ds20) and the Display go. The temperature sensors can be seen on the second picture from above.
The Display has an RGB backlight - when the amplifier is cold, the display is blue, when it is at the right temperature, the display is red.
The trigger input is handled by the Arduino as well I guess ?
Yes, that's correct.
What? You let your wife touch your equipment?! 😱
Just kidding. My wife gets to play music also. 😀
What type of equipment are we talking about here?
Hahaha
Pass DIY Addict
Joined 2000
- Pictures of your diy Pass amplifier
