I've posted a few pictures here before: Pictures of your diy Pass amplifier
Now I'm done with my F5, except for the front panel. 🙂
Very nice, would you mind telling us what RCA sockets those are ?
They are from Neutrik : Phono (RCA) Chassis Connectors - Neutrik
How did you done temperature measuring and display for that?
In the ground next to the toroidal transformer you can see an Arduino Nano, where the two 1-Wire temperature sensors (18ds20) and the Display go. The temperature sensors can be seen on the second picture from above.
The Display has an RGB backlight - when the amplifier is cold, the display is blue, when it is at the right temperature, the display is red.
FX200,
Very nice build! Concept, execution, and workmanship is top notch. Enjoy!
And when are you getting the front panel? That better look good, as you have set the bar high. 🙂
@all -Thank you for the many praise 🙂 🙂
To be honest, I have some ideas, but not "the" right one. 🙄😕
A quick update to my F4. An easy access power switch! My wife was really tired of having to reach around the amp to turn it on and off and ordered me to install an "easy switch"! 😀😀
- Pictures of your diy Pass amplifier
