Pictures of your diy Pass amplifier
My B1 built from parts I had laying around. Sounds really nice.
I've posted a few pictures here before: Pictures of your diy Pass amplifier
Now I'm done with my F5, except for the front panel. 🙂
How did you done temperature measuring and display for that?
In the ground next to the toroidal transformer you can see an Arduino Nano, where the two 1-Wire temperature sensors (18ds20) and the Display go. The temperature sensors can be seen on the second picture from above.
The Display has an RGB backlight - when the amplifier is cold, the display is blue, when it is at the right temperature, the display is red.
