2stageEF high performance class AB power amp / 200W8R / 400W4R
The shown pcb allows to use RECOM RAC02, RAC03, RAC04 or RAC10 series.
I will try both variants during measurements to test for added noise levels...
Should be interesting. Mark Johnson had started a thread regarding small low-leakage transformers for use in an "auxiliary supply" for a power amp. I had asked why he wouldn't consider such RECOM parts for the job and he had replied that he would not consider them due to EMI. Maybe such an aux PSU needs to be well-shielded from the east of the amp. (Even if so, you know I like the idea of just one small aux PSU powering the MCU, output relays and such rather than a bunch of them in an amp.)
If I want a low leakage transformer (for preamps), I use 400V transformers. 400/2x24V is ok to use for +/-12V regulated PSU.
Sajti
SA2015 4 channel VMOS - case layout
CAD top view.
  • red colored: bottom 2.5mm stainless steel plate with ventilation slots.
All needed metal parts are now in production. Will take some weeks to get them all. Laser/CNC cutting, powder coating, anodizing...
SA2015 - 4 channel VMOS
... today new backpanel arrived from schaeffer-ag. Text has been printed instead of engraving. Below the stainless steel inner part of the backpanel "sandwich".
Is the entire enclosure a custom build? I see you mentioned the heat sink and front panel mounting helpers are "universal". It wasn't clear to me that you meant they were purchased as is or designed by you and fabricated for you. I have spent a good while at times cursing the design and quality of Modu's case assembly fixings. Especially in a deeper enclosure where reaching the bottom and corner fixings is nearly impossible with anything installed inside the enclosure. I found myself resorting to J B Weld to bind nuts to their fixings so that the case could be assembled entirely from the outside and never did find a solution for the front panels.
Please show detailed pics of this as you proceed. Perhaps including a top down shot of the rear panel sandwich. I am intrigued how the outer layer will sit flush against the heat sinks given it appears from the photos that the inner layer is of the same dimensions.
Extraordinary attention to detail!
Many thx!
All parts are designed and (c) by me using qcad. Only the anodized front panel is original modu. All other parts are manufactured using my dxf files by different vendors:
  • heatsinks: cooltec.com
  • heatsink cnc and anodizing: schaeffer-ag.de
  • laser cutted stainless steel and iron parts: cutworks.com
  • aluminium panels: schaeffer-ag.de
  • powder coating for iron plates: wolfmair.at
"Universal" heatsink/panel mounting helpers: can be used in principle for 3, 4 and 5 HE cases. Only the 2 small 3mm thick front panel steel parts needs to be designed different per front panel height.
The main reason to design a completely new case variant:
I don't like the top and back panels being mounted above or overlapped over the heatsinks.
BR, Toni
... more details from backpanel "sandwich" ...
Thx Jan and Thimios!
The backpanel "sandwich" is in sum 3mm thick and very stable. Of course you could do a 10 - 12mm thick aluminium backpanel and add blind holes to mount the parts. CNC milling the thick panel is more complex if you add those parts like I am using.(USB port; 3mm headphone socket; Schurter 230VAC EMI filter with fuses and switch ...) but of course would look also extremely professional.
The "sandwich" costs are moderat:
The 1.5mm aluminium backpanel cnc milled and printed in multicolor costs 80 EUR and the 1.5mm laser cutted stainless steel inner backpanel part costs about 30 EUR including shipping.
Have fun, Toni
