What's wrong with the kiss, boy?
Official Court Jester
Joined 2003
good for you
me - after years of playing , fallin' in all usual audiophool mine-holes , decent buffer combined with decent AVC is way to go
everything to avoid resistive attenuator ..... and I tried them all - TKD, P&G ,Alps = all conductive plastic , old Pro series Preh , wirewound from WW2, modern wirewound,Black Beaty , numerous stepped attenuators made with most expensive and cheapest parts ............ of them all - best bang for the buck is white-blue rotary Chinese one from EBay , made with smd resistors
that about attenuators ;
do you need gain stage - it's always best when you don't need it
however , one can be surprised , connecting decent buffer after pot ..... I believe that was also Pa's idea , when he brought B1 ( all iterations) to Greedy Boyz eye .......
Ok
After checking it is the second of ZenMods pictures that works. looking at the terminals this is the wiring. (for 2 : 1 gain)
Joined 2003
zero specimen of Balanced AVC finished
thorough technical testing day after tomorrow
:clown:
(rotary switches stuck in Customs for two weeks already :bawling: )
got them ...... (switches) ...... finally , after 18 days in Custom
each will get proper treatment with vaseline
just inside :rofl:
Joined 2003
nice pic , custom bobbins , ABS plastic , 0.8mm thickness
better than original bobbins - too much slack , so waste in Rdc, coupling and space generally
also - with them can't squeeze two coils on core, for balanced AVC , without sacrifice in Rdc (thinner wire)
Joined 2003
good enough :clown:
I didn't posted sweeps and squares simply .....from two reasons :
- Rout of generator is somewhat wimpier than needed , so will wait** for that measurements with my own gear , where Rout of gen is confirmed and trusted ;also probes (ultragigamegaexpensive) are having some incompatibility with calibration at used levels (my friend working in service center for veeeeery high freq. gear)
-sweeps are just compressed tests already shown on pics
anyway , this pic will say enough - you can see in upper traces that gene output is showing some sweat and tears , driving 10H per coil
whatever , thingie is , as always must be the case , optimized for my Diamond Buffer ....... and "even" Toshiba complementary JFet buffer is driving it with ease
so , to reach desired plateau of performance , I didn't go to make Swiss knife AVC , rather entire package - buffer in front of AVC , as pretty special Swiss knife
(and , as always , proof is in da pudding :) )
**edit - no need to wait - I already measured SE ones at my place and conducted thorough listening tests ...... as Bal AVC is "nothing more" than two SE coils on one core .... things are more than easy and logical to decipher
Joined 2003
it is possible to conduct mono test : you can try running two buffers in parallel , feeding one Telefunken ( then feed both amplifier channels from it)
then disconnect one buffer , leaving just one to drive telefunken
if you have better bass with two in parallel , buffer Rout is issue and you need at least B1 V2. , meaning - complementary JFet buffer
that way you can go with proper dual polarity PSU , avoiding any cap in signal path
