My Q-Watt project
It's down to personal preference.
I've used what i've stated and am more than happy with it. 🙂
All mounted without any problems, nor contact resistance. 😀
My life and my Q-Watt project that i constructed were in my hands when i begun this project, I'm still alive and my Q-Watt is working and sounds fantastic! 😀
Good point... maybe I can solder both sides...? Whenever I tried soldering with these 0.1" connectors in the past the black plastic links just tun to goo... I really hate them. Is it a bad idea to skip the connector and solder the stranded input wires direct through the PCB? At least that wont drip plastic or fatigue off...
As you have been soldering the components (pcb upside down) you'll have noticed that some of the solder passes through the 'holes' into what is the upper side of the pcb, so by rights just add add a tiny 'drop' more of solder onto these points.
If after you have soldered you don't 'see' enough solder on the top of the pcb, just add a tiny drop more on the top side.
Popchops, if the black platic links turn to goo, you're leaving the soldering iron on the solder joint for too long.
You should tin the Inner cable and shield before soldering to the black pins, but also tin the pins too.
You can then wrap the inner cable around the pin and solder together.
The same would apply to the shield cable, but make sure that all the strands are twisted tightly together. To wrap the shield cable around the pin could be tricky and probably too thick, in which case just apply a 'blob' of solder to the pin and introduce the cable towards the pin and solder together.
To insert the cables through the pcb holes and solder sounds ok, but, it'll be difficult to pass the shield cable through the hole.
Thanks Calpe. Did you all use the small black 0.1" connectors supplied by Elector for audio IN. They look quite fragile to me. But then I have been known to overengineer everything...
They are indeed quite fragile. I used a different connector (see attached picture). That connector works very well and it gives me peace of mind 🙂
Hi Delange I found a similar male pcb header made by Molex. Did you solder both ends of this or did you use a female plug on your input cable? Thanks!
I soldered the male connector (header) to the PCB and used the female connector on the sommer cable. This way I can easily disconnect it should the need arrise.
If you look carefully in the pictures I posted you can see the assembly.
If i may delange (or any other Q-Watt constructor), could you please give me some ideas how i can label my rear panel as you have done in you #382 post, thread page 39?
See Delange's rear panel image
The panel was constructed by Shaeffer: https://www.schaeffer-ag.de/en/
It is also possible to use their Front Panel Designer software and print the panel on adhésive paper. Apply that label to the panel and the cover it with adhesive plastic foil for extra protection. That's what I did on the design of my first channel (see initial pics).
I've located from the numerous local Graphic Designers to do what Delange suggested and only for about £10, so i'll probably go for it.
Just need to sort out wording, an example ive posted here
Not forgetting that i still have to fit the front led indicator...
KiloOhms should have small 'k'. Otherwise it's KelvinOhms...
Is this for machining (etching) of the aluminium or for a stick-on label?
I would prefer to omit the THD specs. I also like using lines to link related connectors say from the word Input to Left and Right.
You could give some guidance on what level of attenuation is provided instead of min/max.
POPS
