Official M2 schematic
BTW, what do you use to separate the transformers when you stack them
together? I'm may need to do that for a vfet2 build but am unsure what
works well in practice.
Dennis
Each Antek transformer comes with two rubber pads. I used one on the bottom, two in between the transformers and one on the top. I have stacked transformers in my Aleph J and F6 builds without any issues. As you can see in a photo in one of my previous posts, I can rest the amplifier on one of the heat sinks and the transformers remain in place.
Received today few resistors for M2 Jfet stage.
They are like the labyrinth inside :cheerful:
Somehow I bookmarked two different BOMs for the M2 boards. Can someone skim through my list and make sure it looks correct for the tea-bag boards?
The IRFP240 and IRFP9240 are coming with the boards and the 2SK170BL and 2SJ74BL are coming from Spencer
thanks!
Edit: the R10 and R12 should be quantity 4
awesome, thanks!
Here is what I have for the parts list for them. I'm planning to mount the LEDs in the front of the case (unless that isn't a good idea) next to a power switch.
ta240,
If you have listed the parts for both rails of the power supply, you will need to increase the following:
- 505-MKS2.1/63/5 - total 8 units required
- 625-FEP30DP-E3 - total 8 units required
- 271-100-RC - total 8 units required
